bilstein replacements
Started by pez1, June 15, 2010, 12:19:40 PM
pez1
I have 79 MGB 3.5, in 88 I installed ron hopkinson complete kit, well the left lower Bilstein shock rod has broken at bracket to A arm. My problem is finding replacement shocks in North Am. The #s on the tube (46444 2675 1340) don't match anything Bilstein has. But they are still looking. The car is parked and loosing valuable drive time.......please any help ???
302GT
Check out a site such as QA-1. They list universal shocks by size, maybe something they have will fit (of course then you will need a pair). Consider shocks with adjustment on rebound only.
HealeyRick
Did you ask Bilstein if they could rebuild the ones you have?  I know they offer that service.
pez1
If I could get them to call me back I would ask about rebuild, I've waited three days. but I will keep trying......Watch out for Bilstein service but will post when I hear back, I have called twice !
castlesid
Kevin,
Did you try Moss, they still market the Bilstein kit for the front,
Part no. in the UK TMK30701
Good luck.
Kevin.
HealeyRick
You could just box them up and ship them with a R/O as per here:  http://www.bilsteinus.com/services.php
pez1
Just  came in from the shop ,shock is out (not easy) turns out the rod end is threaded into the mounting bracket , the threaded rod has been pulled out of the bracket stripping the bracket threads ....very strange But I'm going to the Mig welder tomorrow and tack it .....Nothing to lose ...the shock its self seems fine ! keep ya posted, hey thanks for all the help ! Hope I can help someone else. I was at Clevland a few years ago but will miss Indy , to bad, but there in spirit ! Party on
V8-User
I bought the shocks at http://4wheelonline.com/BilsteinShocks.4997
haven't got any problem with it yet
ruben
Bilstein changed their numbering system so crossing those numbers over can be difficult. I recently bought rear Bilsteins for my 122 Volvo but because it is a wagon it took serious serching to find the correct part number. But then when I knew what to order they were at my door in 5 days
