P76 crank
Started by NixVegaGT, December 14, 2007, 12:01:03 PM
NixVegaGT
Does anybody know if the P76 crank has been used in a stroker?
Wotland
Hello, first post on the forum.
Look here : http://homepages.paradise.net.nz/%7Ebdaley/rp.htm
But there is an mistake about pistons source as chevy 302 has 4'' bore size. I think He uses Chevy 305 pistons with top machined to final comp height.
Cheer.
Dimitri
NixVegaGT
Cool! Thanks man. Yeah I saw the 302 and was ?? I figured the same thing: 305 pistons. Thanks man!
Wotland
Hello Nicolas,
Just another thing apparently he used also 5.7'' chevy rods. But with it you have only an stroke/rod ratio of 1.628.
There are very nice 5.85'' rods aviaible from Real Steel in Uk. RS uses this rods in their 5.0 stroker kit (3.510'' stroke). It gives you an stroke/rod ratio of 1.671 with 3.5'' stroke and 1.666 with 3.510'' stroke.
Rod journals of P76 crank can be grind to have 3.510 stroke.
Do you know where to source P76 crank ?
Cheer.
Dimitri
