How thick for aluminum flywheel ?
Started by roverman, September 28, 2015, 07:04:15 PM
Using a Fidanza steel insert, .156" thick, 1050 steel, 9.5" and 6" dia's. Using 7075 T-651 aluminum,(strongest com. avail). Minimum thickness behind insert ? Minimum slippage/temp rise. Cover is rated at 410 ft/lbs.   Thanks, roverman.
