rover automatic to T5
Started by mowog1, December 04, 2014, 12:27:41 PM
mowog1
Question.....A friend of mine is about to sell a Rover V8 from a Discovery that was originally an automatic.
If someone wanted to fit a T5 does he need a Rover manual bell housing....or will he need to obtain a BOP bellhousing (or an aftermarket such as available from D&D???
(I'm not sure of the bolt pattern of the Rover automatic to bell house)
Thanks in advance.
The D$D bellhousing should do the trick.
avbates
Yep, the D+D one is what I used with my 4.2
There  "is" 215 Buick/Olds, if you can find.. Make sure it's the large hole/ big 4 speed bolt pattern. Small hole/pattern fits the early 3 speeds.   Good Luck, roverman.
britcars
I stumbled across a three speed bolt pattern (big hole) BOP bell housing cheap and TIG welded some rough shaped aluminum billet in place then surfaced it in a vertical mill, drilled the 4 speed pattern and installed Timeserts.  Might be prohibitively expensive unless you have access to the right tools.
