AC Compressor Bracket
Started by pspeaks, February 02, 2014, 07:36:36 PM
pspeaks
I need to mount my Saden 709 double V-belt AC compressor on the passenger side of the motor (302 Ford) and I'd rather not fabricate one myself unless I have to.  Can anyone suggest a supplier?
Paul
mgbreis
http://www.alangrovecomponents.com/Small_Block_Ford.htm
The ac "kit" I bought years ago came with a driver's side bracket that I've since concluded came from Alan Grove. I'm not going to use it, because frankly I find it kind of ugly. But, it is solidly built and I'm sure would work fine.
I have the brakets & pulley's from a 5.0 T-Bird.  I don't recall whether they're set up for left or right side, but I can check when I get home.
Addicted
Try CVF racing.  I'm getting an alternator bracket and pulleys from them.  They have a sanden A/C bracket setup.  Not sure if it's what you need, but it's worth a look.
