4AGE SPITFIRE
Started by Sparrow010, October 01, 2010, 09:10:37 AM
Sparrow010
Has any one done this conversion ?
Am picking up a 4AGE with T50 gear box this week end.
Fitting into into a MK 4 Spitty
Any tips, lessions learned would be appreciated.
Andrew
Bugeyev8
Fits great I hear, I have a friend with one in a Morris Minor..sweet little engine, I put a 4AGE 20 Valve in a Bugeye fits great too, are you going to run the EFI ??
Sparrow010
Yep going to run the Std EFI set up and induction.
rampant racing
better give yourself a little more room for that tailstock m8 or it will be an issue down the road.looks like a good swap.good work.
moezilla
Are you able to fit under the stock bonnet and install without mods to the frame / firewall , and just mods to the tranny tunnel?   I have seen one installed with everything left alone - trying to find drawings / photos.
Might do this again to a mKii.
Sparrow010
To fit donk with std inlet manifold under bonnet had to skim a bit of meat of the harmonic balancer. Not happy about this but was only way to get it down with steering rack not being moved. will see if this causes any issues down track.
needed to trim chassie for clutch slave cyl and a bit arround rear half of T 50.
have engine sitting as far back as I can with out mod-ing fire wall.
Rear of trans tunnel is now cut to scratch lines in Pic. A new trans cover will have to be made up, gear stick location now a good 3 inchers back from old Triumph one.
Have fitted a short shift kit to the  T50 and fitted a  shorter lenght gear lever
Radiator mounts have been fabricated
Now for final strip and sand balast of chassie, then the rebuild.
Will keep up dated
random rs
any update on this?? im heading down this route myself with a 79 mk4 but im using a blacktop 20v 4age from corolla ae111 mated to the t50 box, just wondering about the positioning and design of the mounts.....
