215 Olds rebuilder engine for sale
Started by GeminiGuitars, August 14, 2011, 10:37:26 PM
GeminiGuitars
Oldsmobile 215 V8 (3.5 liter or 3500). Aluminum block and heads, aluminum water pump/front cover, and two aluminum intake manifolds. One intake is a 2 barrel, and the other is a 4 barrel. Includes Carter WCFB 4-bbl carburetor.
I originally bought this to rebuild and install in an MGB, but after much consideration I have decided not to do it. Includes block and main bearing caps, heads, front cover, one 2-bbl and one 4-bbl intake manifolds, Carter 4-bbl carb. Only includes what you see in the pictures. Everything is in good rebuildable condition with no cracks and no breaks.
Call 405-924-1896 for more information.  I really don't have any desire to box this up and ship it, so buyer will need to arrange shipping.
<center>    <img src="http://i111.photobucket.com/albums/n145/haggicide/Oldsmobile%20215/explo.jpg" border="0" alt="Photobucket"></a>
<img src="http://i111.photobucket.com/albums/n145/haggicide/Oldsmobile%20215/blocktogether.jpg" border="0" alt="Photobucket"></a>
<img src="http://i111.photobucket.com/albums/n145/haggicide/Oldsmobile%20215/explo2.jpg" border="0" alt="Photobucket"></a>
<img src="http://i111.photobucket.com/albums/n145/haggicide/Oldsmobile%20215/block2.jpg" border="0" alt="Photobucket"></a>
</center>
joe_padavano
FYI, it appears from the photos that you have an Olds block but Buick heads.
GeminiGuitars
Wow--I had not looked closely at these heads until you said that.  You are correct, they are Buick heads.  Do you know if these can be modified/machined to fit the Olds block?
I had two engines, one turnkey and this one, both purchased from the same guy, and thought they were the same.  I apologize for the error.
J Man
As far as I know the Buick heads will work on the Olds block without any issues, but I could be wrong.
