Ford 302 related parts
Started by rficalora, July 30, 2011, 08:37:14 AM
I have several items I didn't use.  Make me an offer if you're interested in any of this...
* MSD 8598 Billet Distributor - steel gear for roller cam; ran it for about 10-20 minutes.  Head was too big with the performer air gap intake/dropped base air cleaner combination I used.
* "Edelbrock" Performer RPM intake -- bolted on during mock-up, but essentially brand new.  Edelbrock in quotes because I'm not positive it is Edelbrock brand.  Pretty sure I bought it from summit or jegs & box says Edelbrock on the label but casting says "Motorsport" instead of Edelbrock.  May have been their store brand but made by Edelbrock.  Anyway it's the same Edelbrock Performer RPM casting as best I can tell.
* Holly Red top fuel pump -- brand new; never taken out of the box.
*  Ford Racing polished valve covers -- brand new; just changed my mind on what I wanted to use.
* Stock 302 valve covers -- used during mock up.  you'd want to paint them but there are no dings/dents
* Tilton 75 master cylinder kit -- brand new.  Reservoir fouled with the brake master & I didn't want to go with remote reservoirs.
* Derale puller fan -- 16", rated @ 2175 CFM.  http://www.jegs.com/i/Derale/259/16516/10002/-1.  Never used.  was about 1/4" too thick with my set-up.  Same fan Ted Lathrop uses so should fit most cars.  My Vintage Air pulley system hangs out a little more than most short nose set-ups.
I'll post pics this evening.
Rob
