4 lug vented Cressida rotor for MGB
Started by mgb260, January 23, 2011, 08:45:11 PM
Carl, It'll be a little while but,here's the plan: I send you the hubs I have with rotors attatched, new wheel bearings/seal rebuilt RX7 calipers (with Mazda name sanded off and painted aluminum Hi-heat). You try them and if you like them, buy at my cost for parts and if not you pay to ship them back. Your master and booster should work fine. I would recommend stainless braided lines and GT rear wheel cylinder. You will need adapter fitting from 10mm x1.0 Jap to either MGB bubble flare or AN3 depending on your flex line(NAPA). Your choice on pads, I usually get the autostore ceramic ones.  My cost for rotors $35 each,calipers $35 each,caliper rebuild kits $40 for both,wheel bearings/seal $30,caliper brakets,bolts,hardware $20. $ 230 total. Hubs/studs and labor free. I would use your positive comments for advertising. What do you think? I will be selling brackets for RX7 and small/large Toyota for $40 pair with bolts,hardware,concentic ring,instructions.
I will likely be using my hubs as I just put new bearings in them last year & shimmed them right where I want 'em.  Plus, I may be drilling them for a new PCD.  My wheel search is not going much better than JB's.
Carl, That's O.K. I just thought you would be the perfect test driver for the brake kit. You know a lot of wheels are dual bolt pattern(4X100mm and 4X4.5"),some  people don't like the 8 hole look though.
"I just thought you would be the perfect test driver for the brake kit."
Well, I just happen to agree.  ;)  Any  chance all that would fit under my  ARE 14X6 wheels? I like the whole concept. 'cept for gaining 3 lbs unsprung weight for the rotors. Aluminum hubs may fix that.
Should but,four piston calipers stick out a bit and sometimes use of wheel spacer 1/4" or so may be required.
Typically I think you will need about 2" from the rotor to the wheel flange.
I have considered alloy hubs and may have to go that way, depending on other factors. The material cost for 6061-T6 for both hubs is around $75+shipping, then there's several hours of machine work and a half dozen set-ups involved. I doubt I could complete the job in an 8 hour day, just to give an idea of what it takes. That'd make for some expensive hubs unless you could find some off another car that'd work.
I measured my parts and am exactly 2" and the caliper sticks up 1/4" and that litte bump about 3/16" more. Can't grind down as it is a fluid passage. 2 1/2" would be better. Looks about the same as the picture above. RX7 stock rotor to wheel is 2 1/2". I might have to use a 1/2" aluminum spacer between hub and rotor for this one and look for a similar rotor with a 1/2" taller hat. RX7 Turbo II stock had a 10.85" diameter rotor and used 14" wheels.
Would this be the smaller Toyota caliper?
Thats the one for the solid rotor, Carl. Notice  it has one small and one large piston to even out pad wear. Even though both my larger ones have even pad wear with equal size pistons. Not nearly as bulky as the RX7 or Large Toyota (S-12 W). Check out the picture of the RX7 above. I am doing brackets for all three. Both Toyota' would be the same. I just wasn't planning on a spacer for the larger ones. It will work fine, though. The height of the Cressida rotor is 40MM and 52MM or aproximately 1/2" more would be ideal for the larger calipers. The S12 - 8 solid rotor caliper bolt right on the MGC like your picture and the TR6. There are 2 different S12-8 , one for solid rotor (76-84 Toyota 4X4 4 cylinder pickup) and vented rotor version like my kit(86-88 Toyota 4X4 4 cylinder pickup and Four Runner). Here's a picture of the vented rotor one on Cressida rotor on TR6:
socorob
I'm going to start looking around locally for some plate to make brackets out of. Should I be looking for 1018 steel plate 5/16-3/8?
You want to try your rotor and caliper on first to determine thickness,or use measurements. I would recommend 2 1/2" between wheel mounting face on hub and rotor. Your bracket might end up on either side of stock mount. Use a minimum of 1/4" steel and if over 1/2" use 6061 aluminum. Here is the best internet supplier of metal: http://www.onlinemetals.com/index.cfm
templaterx7.jpg This template is for a Volvo conversion but gives you an idea. The RX7 holes might end up lower or higher and not straight across. I slide the caliper up or down until the ear is close to the stock mount to determine thickness of bracket.Remember the caliper must be centered, I use equal shims in the caliper slot to center. Also grade 8 bolts and hardware, blue locktite on threads.
Here is a steel bracket used on a BMW:
jarred
Hi.  Great thread.  I have a TVR 3000M over in Seattle and I just started looking at front brake upgrades.  The small and large Toyotas fit but seem HEAVY so have been looking at Wilwood's.  But, I like the idea of the RX7 aluminum calipers.  I have a '87 RX7 turbo rally car which I've run both rally and on the track and can attest to the quality of the Mazda brakes.  Any thoughts on fitment?  I'd be going with the cressida rotors.  Thanks!
jarred
BTW, I can do the FEA stress analysis on your design work.  I just need a .dxf
Bill Young
Jim, I'm getting in late on this deal, what's the center to center dimension on the mounting lugs for the Small Toyota caliper for the solid rotors? Looking for an upgrade for my Midget, but need to cram everything inside a 13" wheel so smaller is better. Midget mounting is same as MGB I beleive at 3.25" center to center.
Jared, Picture of Volvo template gives dimensions for bolt spacing on RX7 calipers.  You can use 11" Corrado rotors also if you open up the center hole. They have neat little cooling windows in hat. Might need 1/2" spacer between hub and rotor to allow somewhat thick RX7 caliper  to clear wheel. Basically allow 2 1/2" from wheel mounting face on hub to rotor. Bill, I think the small Toyota 4 pot would be excellent on the Midget! The bolt spacing is 3 1/2". Clock the lower caliper mount above the lower mounting hole. You might have to grind the inside edge of the caliper housing and pads because of the smaller diameter rotor. Also you would need shims behind the pads because of the thinner rotor.
Robbie has mounted his RX7 calipers and Nissan pickup rotors on his Alpine. I'm sure he'll post information on this site.
Bill Young
Thanks Jim. Clocking the caliper isn't an option on the Midget, run into clearance issues with the lower control arm or the shock arm up top at full lock unless the caliper is basically dead center and on the short side as well. I have tried to fit the RX7 calipers and also some Volvo calipers without luck because of the clearance issue. Austin Princess caliipers are a bolt on but basically un obtainable here in the US. I've read that there are some early Land Rover calipers that also will fit but again hard to find here in the US but I'm looking into that now. Looks like I might have to go with the more expensive Wilwoods and have mounts machined for those.
Bill, Maybe you could offset drill the mounts and calipers to make up the 1/8" difference per side and use a larger diameter mounting bolt.
Or buy that Austin Princess on ebay and get the seller to just send you the calipers...
socorob
Heres a picture of the back view. I finally got to drive the car today after a few months of upgrades. I have 1 water leak t address and the turning on and off at the right temp of the electric fans, and ill be back on the road.
Robbie, Cool! How would you rate the brake upgrade compared to stock brakes.
jarred
Hi Jim,
I'm a little lost.  What of all these cars share the same hub with the TR6?  I know the MGB and Midget do not, what about the Alpine pictured above?  Have the RX7 brakes already been fit to the TR6 hub by someone?   Thanks.
All of the hubs are different but the principal is the same. A piece of aluminum or steel bar stock adapter from the stock 3 1/2"(3 1/4" MGB) mount to the 6 1/8" mount of the RX7. Thickness will vary. Look closely at the Volvo picture and Robbie's Sunbeam picture. The original (same as Toyota pattern) is in the middle of the adapter,RX7 are outer holes.
socorob
Well, I only drove the car about a mile because I have a slow drip from the Saab thermostat t I put in, but the brakes have less pedal travel and I can actually lock them up now, which I was never able to do before. I'm using a Nissan F10 master, 3/4 bore. I also need to figure out if the back is getting enough braking. Any suggestions on how to do that?
