Starter solenoid position
Started by NixVegaGT, December 08, 2009, 09:17:43 AM
bsa_m21
You mean like this:
Looks like it might almost be a direct fit!
M.
Martin, close. Series II starts in 1990. I don't know if "turbo" starter has more poop.Only for "out-back" installs, on CR engines.roverman.
Bruce Mills
Nope. no bolt on aluminum nose.
With regards to my starter dilemma, I called the company and calmly explained my stater problem. With no prompting he told me to send it back COD and he still had my original starter so he is now going to source the parts to repair it.
Isn't that the way it is. You figure your going to have a big problem and everything goes as smooth as glass.
Here is a picture of the original starter (after conversion)
v8ian
In the past I have modified rover starters  , cutting off the bolt lugs, and reducing the size of the pinion support so the starter can be rotated to clear, I made small machine type clamps to retain the starter, but I cant see any reason why  2 lengths of threaded bar and a plate across the back of the starter would not work, or even weld the lugs back in a differernt place,
NixVegaGT
On the MR2 starter. Are you saying it spins correctly if we mounted it on the tranny side? Or just tried mounting it in the stock location?
Yes Nic Ol' chum, it's an oem. reverse rotation starter ! Happened to come with one of the T-axles. Most Toyotas are clockwise rotation on the front veiw of crank, so yes, its spins conventional engines correctly from tranny side. Opens up some clearence options/no exhaust cooking.roverman.
Bruce and clan, FWIW, I have genuine "Tilton", it looks identical to yours Bruce, only cast nose is machined-off to take a replaceable billet nose. 2010-I'm gonna start somthin! roverman.
pcmenten
Art, I have heard of 5 axis automated milling machines that can take a program and machine parts. The place I work has them, making oddball prototype stuff. I often wonder why adapters are so expensive when they could be produced on a machine like this in a matter of minutes. I paid D&D $200 for a simple plate to adapt a Ford T5 to the BOP 215 3sp bellhousing. The cost of the aluminum blank for that job would have been, what, $30? Rather profitable part, that plate.
So, I wonder how hard it could be to design a replacement nose for a gear reduction starter. Hell, a fella could design numerous noses for a variety of starters and bellhousings/blocks.
(It also begs the question of; why are roller cam blanks so damned expensive? Is the cam material that costly?)
bsa_m21
A company called McLeod Industries (www.mcleodind.com) makes a gear reduction starter with various adaptor plates, including on for the Buick 215.....
But if anyone wants to make their own, here are the stock measurements.
Regards,
M.
Paul,
I would think you need to factor in the cost of that machine, design time  and the rather limited demand for the part.
Paul and all, demand, volume,overhead,"product liability insurance"(biggie)-I'm not sure how China is on this one. Paul, you paid $200 for a $5. piece of alum., in the right configuration, because you couldn't/wouldn't, do it yourself ? Time versus $, most of us are up against it. #8620 cam billet steel is relatively cheap. Lack of "volume" ,for sbb/Rover, billet cams, makes them expensive. One need only shop roller cams for"popular" engines, more 8620 steel in them, and yet very good prices."Tilton" style gear red. starters, new, e-bay, $70., all day! Why?, volume/China.  I'm goin with starter(left) in pic's, Tilton copy. It's available/ready for bolt-on nose. Remnant alum.,small quantities, $3.50 lb.? New, large quantities, $2.50 lb.?  If "we", placed an order for (50) roller cams, you can bet, it would be a very good price. Wow!, my first "soap box" for 2010- Thanx, roverman.
