Building A Race Olds 215
Started by castlesid, August 07, 2009, 01:27:06 PM
Dan Jones
> The 2001cc-3651cc class seems to be the least restictive apart from the
> manifold.
I recommend that you have the heads and intake ported together.
I've flow bench and dyno tested several dual plane intakes and
they've all had 4 good runners and 4 bad.  By cutting down the
divider and radiusing the port entries, we've made good gains by
bringing up the bad runners to match the good.  Good is relative
here as even the best runners were still a restriction to the
heads.  I'd be tempted to gather 2 or 3 dual plane intakes to
experiment on and dyno test.  On one, I'd remove the divider
entirely, making it essentially a long runner single plane.
On another, I'd use the flow bench to work the divider and port
entry to equalize flow.  Use a carb spacer, if the rules permit.
> The Buick 2bbl intake is very similar to the 4bbl intake. In
> fact it is quite possible it has the same runners and just a
> different pad for the carb.
I have both here and they are the same except for the pad
area for the carb.
> The Olds heads modified by Dwayne Porter have inlet runners 1"
> wide x 1.7" tall which is just a shade smaller than stock 300
> runners and for a 215 I feel are adequate, and the flow figures
> look encouraging.
Some additional flow numbers for consideration:
In the September-December 2003 issue of the British V8 Newsletter, Kurt
Schley reports the results of a maximum porting effort on a set of Olds
215 heads (the 51 cc version, casting suffix -746).  These are the low
compression Olds heads which are going on a 289 cubic inch stroker Olds
215 (welded iron 3.75" stroke crank).  The porting was performed by
Dwayne Porter (c/o Motion Machine 802-951-1955).
The article does not say what pressure drop the heads were tested
at but states the flow numbers were corrected to 28" H2O.  This
means the heads were flowed at some lower pressure drop and ratio'd
by the square root of the ratio of the pressure drops.  These numbers
are likely to be optimistic compared to flow actually taken at 28".
Valve train used:
 Ferrea P/N F6223 (Intake valve for a Ford 2.3L), 1.74" head diameter,
 11/32" diameter stem, 4.8 long, 0.4" tip.
 Ferrea P/N F6224 (Ehaust valve for a Ford 2.3L), 1.50" head diameter,
 Comp Cams valve springs P/N COM-901-16 (ouer spring with damper),
 1.5" OD, 1.080" ID, 110 lbs @ 1.65" load at checking height, 290 lbs @
 1.150" load at open height , 1.110" coil bind height
 Comp Cams retainers P/N COM-743-16 steel 7 degrees lock angle.
The valve head diameters were reduced to 1.62"/1.4", so the stock valve
seats could be retained.
Test #1 Stock head 1.525"/1.35" valves
Test #2 Stock valves but full head porting, intake opened to 1.70" x 1.00",
        30 degree back cut on valves, competition valve job
Test #3 As Test #2 but with 1.62" intake valves, 1.40" exhaust valves
        (intake and exhaust backcut)
Test #4 As Test #3 but intakes opened to 1.80" X 1.00", fully polished
        runners, guides streamline
        Test #1          Test #2          Test #3         Test #4
 Valve  Stock Olds       Ported Olds      Pored Olds      Ported Olds
 Lift   215 heads        215 heads        215 heads       215 heads
 (inch) Intake  Exhaust  Intake  Exhaust  Intake Exhaust  Intake Exhaust
        1.525"  1.350"   1.525"  1.350"   1.620"  1.400"  1.620"  1.400"
 0.100    43     35        48     36        51     45       51     46
 0.150    63     52        72     55        77     64       77     64
 0.200    85     65        95     73       104     76      104     78
 0.250   104     73       111     85       128     88      128     90
 0.300   116     77       124     96       146     99      147    101
 0.350   122     80       138    105       159    108      161    112
 0.400   128     81       150    110       168    114      172    118
 0.450   133     84       158    114       168    119      173    123
 0.500   134     84       165    119       170    124      174    126
 0.550   136     84       168    120       173    126      176    129
 0.600   136     84       168    122       174    127      178    130
A local (St. Louis, MO) MGBV8 owner had a shop that is no longer in
business port a set of Rover 3.9L heads.
        Rover 3.9L
 Lift   aluminum heads
        Stage 4 Porting
0.200   96.7    80.1
0.300   143.9   106.6
0.400   177.1   127.0
0.450   180.6   134.3
0.500   181.0   139.7
0.550   181.0   142.8
My ported Buick 300 cylinder heads:
 Valve  Buick 300     Exh/Int
 Lift   1964          ratio
 (inch) aluminum      (%)
        ported
        Int    Exh
        1.775" 1.5"
 0.100   66    47    71.2
 0.150   99    82    82.8
 0.200  129   104    80.6
 0.250  155   119    76.8
 0.300  174   130    74.7
 0.350  187   139    74.3
 0.400  191   146    76.4
 0.450  194   150    77.3
 0.500  196   152    77.6
 0.550  200   153    76.5
 0.600  200   153    76.5
Flow numbers were taken on a Superflow bench at 28" H2O with a clayed intake
radius but no exhaust pipe.  Heads were ported by Jon Carls:
 JDC Engineering
 711 Walnut
 Minonk, IL 61760
 309 275-2761 (cell)
6000 Series Ferrea Buick V6 Stage 1 valves were used.  Intake valves are
part number F6238 (1.775" head diameter, 11/32" stem, 4.735" long with a
0.271" tip).  Exhausts are part number F6237 (1.5" head diameter, 11/32"
stem, 4.735" long with a 0.254" tip).  Intake head shape is a 10 degree
Super Flo.  Exhaust is a 29 degree tulip.  Ferreas 6000 Series valves are
competition parts suitable for solid roller cams.  The larger valves
required larger seats, p/n 30903 for the intake and p/n 30647 for the
exhaust.  I gave Jon a junk head to experiment on and he said he actually
pulled a bit better numbers on the test head.  I can see spots where he
intentionally went through the aluminum into the water jacket.  These
heads are destined for a street application, so it was important to leave
adequate wall thickness.  An all out race heads would recieve more porting.
I'm pleased with the results.  The exhaust to intake flow ratio is good
and the low and mid-lift numbers are excellent.
Pictures of the ported heads are shown here:
 http://www.bacomatic.org/gallery2/v/hidden/dan/dan-cars/album10/album12/?g2_page=1
 http://www.bacomatic.org/gallery2/v/hidden/dan/dan-cars/album10/album12/?g2_page=2
 http://www.bacomatic.org/gallery2/v/hidden/dan/dan-cars/album10/album12/?g2_page=3
 http://www.bacomatic.org/gallery2/v/hidden/dan/dan-cars/album10/album12/?g2_page=4
Do your rules allow the heads to be welded?  If so, you might wish to look at
some pictures of a maximum effort set of Rover heads ported by David Vizard:
 http://www.bacomatic.org/gallery2/v/hidden/dan/dan-cars/album10/album12/?g2_page=6
Be aware that the 2 barrel version of the Olds 215 came with large chamber
heads that would not be suitable for your race motor.  The Two bbl heads
were suffix-746 and 51 cc's.  The 4 barrel cars were equipped with suffix
-829 heads (43 cc's) or suffix -534 heads (38 cc's).
For your application, I'd be looking at running a flat top piston in a
zero-decked block with the 37 cc Buick 215 or 38 cc Olds heads milled
to a smaller combustion chamber volume.  That should get you in the 13:1
compression range.  An alternative to milling is to have the chambers
welded.
Come to think of it, what you really need is you need is my '62 Buick 215 heads.
GM cast a small batch (maybe 50 pairs) of the Buick 215 heads which combine the
small 215 combustion chambers with larger Buick 300 ports.  These heads can be
ported beyond what a normal 215 or Rover head can but appear identical to a
Buick 215 externally and carry a GM part number.  These heads were used by racers
like Mickey Thompson who ran a stock block Buick 215 at Indy in 1962 (qualified
8th with Dan Gurney driving) and Lance Reventlow who used the engine is his
mid-engine Scarab road race car.  See "Souping the Special" here:
 http://www.bacomatic.org/gallery2/v/hidden/dan/dan-cars/album10/album12/?g2_page=7
Dan Jones
Dale Spooner can be contacted at :
Motion Machine Inc
(434) 799-2604
560 Memorial Dr
Danville, VA 24541
castlesid
Hi Dan,
As usual, incredible information that will take my feeble brain a while to absorb.
No welding of heads is permitted.
Inlet manifold may be modified but no metal may be added.
I felt that the smallest chamber Olds 215 head with the more centralised valve would offer some benefit in the small bore 215 engine. would you agree with this?
If using one of the stock 2 barrel manifolds with mods, how limiting to power production do you think it will be.
Bear in mind that we are looking for the best stock combo to base the engine on the regs limit us to using the block crank rods heads and inlet manifold and 2 barrel catb which must all come from the same engine.
It is meant to be a low budget club racing series so you vcan understand why, but it is nice to find an edge!
If it's not rude to ask, how much does your head guy charge to do a pair of the big valve heads.
Yes your hybrid 215/300 heads would be nice, but I doubt that you would part with them for a figure we could afford.!
Regards,
Kevin.
Dan Jones
> agree with this?
The Olds may have slightly decreased shrouding but I like the Buick
spark plug location better and the chamber design rocks the piston
a bit less at TDC (not important on a stock stroke engine).  All of
my experience is with the Buick and Rover versions so I can't say
much about the Olds.  It may come down to which heads have the best
porting potential.
Do you have a copy of "Modifying GM's aluminum V8's"?  In that publication,
the results of 19 separate dyno tests of both the Olds and Buick 215's are
presented.  In stock 2 barrel form, the Buick made better power than the
Olds across the RPM range.  The Buick also made the best power in modified
form but you'll need to closely study the results as those tests were not
necessarily on equivalent engines.
What will your RPM band be?
My notes say it was $1050 for the Stage III porting.  That included
the porting labor, flow bench and machine work, guides, seats, valve
job, etc.  I supplied the Ferrea Buick V6 Stage 1 valves.  To use
those valves you have to replace the intake and exhaust seats and
then port the bowls out to match the new seats.  Also, to port the
bowls, the guides need to be driven out to make room for the cutter.
As soon as I'm done flowing the GM race heads in their baseline form,
I plan on taking them up to John for some additional porting (larger
intake valve).  I think I have a 2 barrel intake and carb I could take
up to John if that's of any help.  I could also also take a 215 block,
if he needs one to check valve to wall clearance.
Yup, they aren't for sale :-)
Dan Jones
castlesid
Dan,
Well lets start from the first obstruction in the plumbing. If the modified two barrel Rochester can flow 500CFM and the manifold can be modified to work with that flow figure, what spec heads would we need to use that flow capacity and what RPM potential do you think we may get.
From what I've read it seems the 215 Buick or other versions can make good Peak power at approx 7250 RPM
The restrictions we have in that we must use stock rods and one of the stock inlets with a stock 2 barrel carb may limit the RPM limit that we can achieve, I'm also somewhat concerned about the safe RPM limit for the rods.which can only be deburred, polished shotpeened etc.
Clearly if our RPM goal is too high we would have to set the spec to achieve a lower peak power output at lower RPM's and sacrifice some power, what do you think?
Kevin Jackson.
Kevin, the Olds Jetfire (turbo) engine came with the small chamber heads. These were nearly identical to the Olds 4bbl heads but had a different casting number and IIRC a slight difference in the chamber. Since that gives you the package of possibly a good 2bbl intake with the 38cc chambers it might be worth scouting around for one, or at least the pieces. That intake looks identical to the one I had.
castlesid
Thanks for that.
Trying to make some sense of the of the likely operating range of the engine. I seems with standard rods and probably inlet we be limited to approx 6500 RPM so will have to sacrifice some ultimate top end HP but if we can make 250 + BHP I think it could be enough to make the car competive, the kit cars used are mainly Lotus 7 Westfield type copies weighing in at not more than 600 Kg/ 1320lb so will not be slow at around 425 BHP/Ton. Wish I was still young enough to drive one.
Kevin.
castlesid
Carl,
Block girdle is in our spec and I can get one without a problem.
Thanks for the thought though.
Kevin.
NixVegaGT
I'm with Carl the stock rods are great. They are forged and plenty strong for high RPM. I may retract my earlier pitch for the Olds heads based on the ability to port the heads. It's pretty obvious that the Buick heads have more to offer. The other factor is the ability to make higher compression with the Buick heads. You can get a bunch of power from the higher compression. That was a strong argument from Dan's position. I guess it comes down to fuel restriction.
With the girdle, the limiting factor for RPM is the valve train from a mechanical standpoint. I think you'll be covered there. Then it's just trying to get the intake to flow and avoid detonation at all costs. Do you guys use Ethanol over there? I suppose there is a fuel restriction too...
This is really fun.
castlesid
Guys,
The V8 has gone on hold for the moment as my friend has I feel sensibly, decided to do a season in a smaller engine class to get some track experience, but is still keen to do the V8 in due course.
So all your helpful information will go on file and hopefully we can pick this up again next year.
Many thanks,
Kevin.
