Gear ratio woo`s
Started by Solarman, December 18, 2007, 07:50:06 PM
Solarman
I have a Ford 8" and it has 3.4:1 ratio how will this compare to the MGB 3.9:1. Shoul I change this? what are the pros and cons?
I think you might find Dan Masters' nifty calculator very helpful - this link will open as an Excel spreadsheet.
http://www.britishv8.org/Articles/chart.xls
If you enter gear ratios, tire diameter, etc., the calculator correlate engine speed (shift points) to road speed for you.
Citron
Curtis,
That is a great spread sheet.  I am going to try a 3.0 ratio.  It will put RPM at about 2200 at 80.  Just where I think it should be.
Will have to run again at MAxton and see if I'm faster that was y.  Now I am at 110 at 5700 in third gear. ( 4 speed Auto.)
The new gear will put me down under 4000 at the same speed.
Steve
NixVegaGT
That's a hot car, man! I love the custom headlight setup. What engine are you running now? If it's a transplant with more power I think you'll like the Ford ratio better. With more torque you won't need the extra gear and you can lower your crusing RPMs.
Solarman
It is a Ford 302 400hp to the wheels and 12.1 sec 1/4 mile . Light are Dodge Neon
Thanks man
