5.0 in my tr6 oil filter and exhaust
Started by vincentscottjensen, April 29, 2026, 08:16:53 PM
vincentscottjensen
Hi helpers. I'm fitting a 5.0 and t5 in my 70 tr6. Please see the attachments. Any advice on fitting the filter and steering shaft would be very helpful.
Al Moor
Triumphant4A
Couple of pics of how I did mine.
Remote filter on Driver's side of the engine bay
Steering shaft links from OEM column to OEM rack in the original location
3 heim joints and two heavy gussets through the inner fender wall to keep everything rock solid.
It looks like something that would feel a bit wrong, but I honestly can't feel any change from before.
If you blow the pic up you can see how close it comes to the valve cover on driver's side.  I ground  almost 3/16" off the corner of the aluminum valve cover to be sure it would stay clear - has never touched.
vincentscottjensen
Looks great. If possible could you give me your engine height and distance back?  I'm about ready to pull my mock up out and start engine assembly. I'll include a photo or 2.
vincentscottjensen
Did you keep the front crossmember?
Triumphant4A
From the pics, your engine is further fwd than mine.  I pushed the 302 as far back as possible to avoid having to change steering mounts.  As for height, I have about 3/8" between the air filter and the hood.  I made mounts similar to Dan Masters to get it as low as possible. I have attached a couple shots for comparison.
vincentscottjensen
Hi. Great job. Please tell me where your harmonic balancer ends up. Right now my oil pan lip is kissing the rack tube.
vincentscottjensen
Well, I'm making some progress. The engine is in and also my exhaust manifolds are in place. I'm going to fit the radiator and my car will have an electric water pump, so I'm wondering about the stock radiator support. Please see the picture and let me know if I can modify that or if it can be deleted. I could section the support and have it end up in front of the balancer. If the piece is structural then i must keep it close to in place right?. Thank you so much.
On Dan's TR4A and his TR6 we always considered that a necessary suspension stiffener although I suppose you might be able to get by without it. No real issues I can see with modifying it as long as the ends stay where they are. It just keeps the top end of things from collapsing towards the middle.
vincentscottjensen
Thank you. I'll cut it near the small support arms widen and weld.
Yes, be mindful of your alternator clearance and such.
Triumphant4A
Hopefully not too late in responding, I have been away from the project helping family out of state.
Here is a shot that shows the advantage of sliding back as far as possible.  balancer is behind the rack.
Triumphant4A
Final, unsolicited photo - when stuffing in a V8, clearance is the test. As you can see in the attached pic, the engine is 1/4 inch behind the factory brace and the coling fan is 1/4" tot he opposite side. Just enough to avoid conflict.
