Rolls Royce Van Der Plas???
Started by old3, September 04, 2010, 03:01:32 AM
old3
Hello, new member here from the Northeastern USA. Not really well versed in British cars but I recently found a project car, (its been sitting for years in a local driveway), that seems quite an odd ball. Its clearly showing Rolls Royce badging on the trunklid, the hood ornament, the steering wheel and wheel covers but its a Van-Der Plas model. My research shows these were a joint built car between BMC and Austin using a RR engine but I can find no evidence of a version specifically badged as a Rolls. Anyone have any knowledge of a RRoyce version sold as a RRoyce?
It seems factory produced, the trunk lid, for example has a rectangular RR badge and lacks the Austin handle in the center. Everything Labeling RR seems factory installed and not added on after original purchase.
Thank you all for any info regarding this vehicle.
alana
old3
2 tone, blue and silver. Is this a "real" Rolls? I guess its not a rare a bird as I suspected? Thanks, Jim.
alana
It's an Austin iirc but with a Rolls engine.
old3
I read the history on the model but never found one labeled as a Rolls, this one clearly is, looks original too. Thanks!
kerbau53
I believe you are looking at a Vanden Plas Princess 4 litre R. Basically an Austin Princess with a RR 6 cyl OHV engine sourced from a British Army jeep as I recall. My dad bought one in 1966 and drove it for 30+ years. I can't speak to rust issues as the car was garaged it's whole life. It can easily keep up with modern traffic although the auto box is a bit clunky by todays standards. Suspension is lever damper front and rear. Leaf spring rear. Lower wishbones require MGB V8 bushes with the steel sleeve removed. Interior would be a bit pricey to redo properly.
Much of the history of the Vanden Plas company and its associations with Austin and with Rolls Royce is contained in this article about a later model in the series: <a href="http://www.britishv8.org/Other/JohnCrosse.htm">The Vanden Plas Princess 3-litre MkII</a>
These two paragraphs are especially relevant:
QuoteIn 1952, Austin became part of the British Motor Corporation ("BMC"), and from 1956, Vanden Plas cars were no longer badged "Austin" because BMC considered the Vanden Plas name more upscale and entirely sufficient on its own.
As if this decision about badging wasn't confusing enough, however, BMC also decided to simultaneously offer two entirely different Vanden Plas "Princess" models. The 4-litre Princess would continue indefinitely... and in 1959, Vanden Plas introduced an entirely new and more modern 3-litre "Princess". The 3-litre Princess was also a luxury automobile, but it was better suited for a member of parliament than for a member of the royal family. During the 3-litre Princess's seven year production life, 12,703 examples were built.
