Buick 300 V8 build recipe
Started by mgb260, January 27, 2022, 04:39:36 PM
Airwreckc
All good advice--it'll be interesting to see how things work out.  Great insight from all of you, as I thought.  The 2.3 Turbo pistons look very promising (and super cheap at $14 each).
Check the front rod bolt heads against the suction galley casting and the shoulders against the rear cam lobes. .050" clearance is good if you can get it. May have to shave one or two shoulders and recess one or two capscrews.
Airwreckc
Airwreckc
I'm getting to tear down my 300.  Can anyone suggest a good book (or perhaps Youtube) that will guide this--and also a good manual on rebuilding it.  I've rebuild engines before, just not this particular engine.  Thanks.
It isn't much different except the oiling mods and tighter clearances .Do a search here  and on V8Buick for more information.
Airwreckc
minorv8
I have a crank with 91,.5 mm stroke and have later 5.95" SBC rods (for 2,100" journal). I am using special inserts to suit that rod bore and 2,000" journal. That combination clears the cam but did not rotate inside the block. I think I had to grind clearance at 2 locations. The issue was with the cap head bolts and I think I also machined a small chamfer at the head of the rod bolts. I did not like grinding the block at oil gallery that much.
Airwreckc
Thanks Jukka, I assume I will also have to chamfer a few of the bolts, as well.
Airwreckc
Can someone look at the UEM piston link tthat was previously posted?  I checked yesterday and, unless I'm mistaken, they have eliminated the option of searching by bore size and other criteria--making it mush less useful than a few days ago :(
They have definitely been working on the website.  Webmasters seem to think they have to update & modify site just to make them fresh. Doesn't always make them better.
Select a piston brand from Product Lines.  Scroll down & use the Filters column on the left to select Bore Diameter.  Not quite as handy or useful as it was, though.
Glad they kept the calculators.
Airwreckc
Thanks Carl, wanted to be sure I wasn't missing something.  What was a five minute search will now take a lot longer.  Oh well.
Jukka, Did your rods have 7/16" bolts? That will add to the width over the 3/8".
minorv8
Yes, 7/16" bolts. But since my rod bid end width had to be a touch over 0.76" it did not matter whether they are 3/8" or 7/16".
The crank is a weird stroker item for TVR500 i.e. 5.0 litre version.
