Rims
Started by 1967Spitfire, March 31, 2021, 06:20:47 AM
1967Spitfire
What rims and tires will fit a 1967 Triumph Spitfire, four lugs? I've read that Miata and some Toyota rims will work. Does anyone know?
dwtr6v8
A 4-bolt pattern.
3 ¾" (95.25mm) between centers
Most on BV8 modify their rides, but.........
If you are staying stock on your bolt pattern
http://www.triumphspitfire.com/wheels.html
For tires
http://www.triumphspitfire.com/tirerec.html
Spitfire 350
Is your Ford rear end the same pattern?
waterbucket
The only widely available rims to fit secondhand are from a MGF/TF, the wheel offset is 25/28mm. Do not be put off from buying from the UK as shipping is only $150 for DHL & $170 for UPS.
https://www.ebay.co.uk/itm/MGF-MG-TF-wheels-with-tyres-4x-MGTF-square-spoke-alloy-wheels-15-inch/233922553701?hash=item3676dee765%3Ag%3ABhIAAOSw5J5gT7Yc&LH_BIN=1
tr8
TR7 and TR8, Lotus Europa, lotus 7, GT6, lots of aftermarket wheels on Ebay
Just search 4x95.25 wheels
