215 engines and parts for sale
Started by dfair4tb, February 23, 2021, 05:56:01 PM
dfair4tb
1 buick 215 built to 305 ci (unassembled) consisting of the following parts:One 215 block sleeved and bored to 3.780,aligned honed and decked parallel t0 mains.One 300 crank ground to std. mains and.010 rods.Crank seal adapter fitted to block.8 pistons TRW forged #L-2455.8 chevy 283 HD rods,sized to crank and assembled to pistons with pins.Main and rod bearing sets.Ring set with total seal top ring.1 set of 64 buick 300 heads fitted with new guides,valve seats , seals, manley DH-B intake valve and  manley G-GB exhaust valve,HD valve springs,roller tip rockers,chrome rocker shafts,ported,three angle valve job and matched to intake manifold.1 crane cam #901151 grind #F-228/3067-8 and one #901171 grind # F-248/3334-8,and crane lifters #99250-16.1 set 5/16" pushrods.1cloyes true roller timing chain set.1 melling high volume oil pump.1 set ARP head studs.1 set ARP main studs.1 buick V-6 timing chain cover.1FLO-KOOL water pump.1 oil pump pick-up tube D&D #25505644.1 distributer gear D&D #602159.1 MGB header package D&D #RV-8-BT.1 MGB motor mount set D&D #7780-13.1 water pump pulley D&D #9604.1 OFFY 360 intake manifold.1set of OFFY aluminum valve covers.1 used holley carb 4777.1 300 front balancer.1 MCLEOD aluminum flywheel with ring gear.1 oil pan.1 alternator 100 amp.1 aluminum air cleaner with element 12x2 oval.Engine package price $4000.00.Contact David Fair @ 813 2397584 in Plant city,Fla.
dfair4tb
1 ford motorsports T-5 transmission FMS-M-7003-Z,bought new ,never used.1 ford motorsports clutch7560-A302N.1 mcleod hyd. throw-out bearing MCL1400.1 mcleod spacer MCL1439.1 trans-dapt bell housing and adapter for 215 engine to T-5.Package price $2000.00.Contact David Fair @ 8132397584 in Plant City,Fla.
dfair4tb
1 bare buick 215 block bored to .030 over. 1 buick 215 crank turned .010-.010.1 rover 215 block assembly with heads.1 olds 215 two-barrel engine complete.1 bare buick 215 block.2 buick 215 cranks.1 offy 360 intake manifold, 1 offy 360 intake manifold with-out water jacket.1 set KB 215 3/8" pushrods.1 set 64 buick 300 heads.1 64 buick 300 aluminum flywheel.1 buick 215 trans-dapt bell housing HE-25.1 trans-dapt adapter plate 0019.Misc. 215 pistons,rods ,cams and other engine parts.Package price $1000.00.Contac t David Fair @ 8132397584 in Plant City,Fla.
