Mark Warner's 1959 Austin Healey Bugeye Sprite w/ Turbocharged Rotary Engine
Started by bugeyebug, October 30, 2020, 09:41:15 AM
bugeyebug
Owner: Mark Warner
City: Arizona
Car Model: 1959 Austin Healey Bugeye Sprite
Engine: Turbocharged Mazda Rotary
Current Status as of October 30, 2020: not-running; requires an engine rebuild, complete electrical system, gauges, lots of little engine things to be figured out (e.g., oil supply/return to the turbocharger), stiffer/taller rear springs, etc., etc., etc....
Engine: Second-generation Japanese Domestic Market (JDM) 13b; T04 Turbocharger w/ Top-mount Ebay Intercooler, DIY sheet-metal intake manifold, Ford Mustang throttle body, TiAL blow-off valve (BOV)
Cooling: Griffin Radiator, Earl's Oil cooler
Exhaust: 4-inch Downpipe, DIY straight-through "muffler" exiting in front of rear tires
Transmission: 2nd-gen Mazda RX/7 with custom shifter relocation
Rear Axle/Suspension: Custom DIY with Mazda Miata Limited Slip Differential (LSD), custom upper and lower A-arms, CV joints and shortened axles
Front Susp.: Miata hubs and spindles, custom upper/lower arms, Sweet Engineering rack & pinion
Brakes: Miata Front & Rears
Wheels/Tires: 16-inch Mazda Miatas
Body Mods: Tip-forward bonnet, cowl-induction for the intercooler, front blended scoop for oil cooler, roll bars holes, fuel tank filler relocation
Interior: Paddy Hopkirk seats, sheet metal dash and tunnel, removable steering wheel
Electrical: TBD
