Removing dizzy
Started by tr7v8mike, May 15, 2020, 09:42:30 PM
tr7v8mike
Hi, I have a RR P38 engine and I am going to remove the dizzy and install electronic ignition (Megasquirt).  Does anyone know where I can get a plug for the hole left by removal of the dizzy?  Rimmer Bros don't have anything.
Mike
No, but I have happily used the Lumenition Optronic system on a number of cars, retains the dizzy.
Currently in my Land Rover with Rover V8, and my Rambler with factory 327.
TR8Driver
Does that engine have a crank-driven oil pump?  If not, you will need something to drive the oil pump.  I saw, but can't find anymore, a place in the UK that will remove the top of the dizzy and put on a nice caps.
TR8Driver
Check out the "dumpy dizzy":
https://www.megasquirt-v8.co.uk/ms_3-9_efi_serpentine.php
If you still need to drive the oil pump, check out the "dinky dizzy":
https://www.megasquirt-v8.co.uk/ms_3-5_etc.php
tr7v8mike
Thanks Darrell, perfect solution.
