Interesting cast iron header for Rover/Buick v8s
Started by RDMG, December 16, 2019, 09:57:55 AM
RDMG
I recently bought a complete 4.0L v8 from a 1999 Land Rover Discovery, and these are the stock headers I removed from it:
Note they aren't mirror images of each other.  The header on the right side is 4-into-2, with the 2-into-1 joint somewhere past the joint on the down pipe.
I'm thinking if you can find two Discos of that vintage, you could have a matched set.
I'm not sure if they would clear the outside edge of the MGB frame rails in an RV8 through-the-wings exhaust configuration, but I bet they would with a slightly wider Buick 300.
