noticed something today
Started by rficalora, May 02, 2016, 11:10:25 PM
I can make my engine temp drop by about 4-5 degrees by turning off my headlights.  Oil pressure drops slightly too when headlights are turned off too...  tells me the headlights are somehow affecting reference voltage or ground.
Will have to do a little investigation to figure out exactly what's going on but thinking it has to be ground related.  My headlights run through a relay and the dash switch simply provides ground to the relay switch (85 or 86, don't recall which but don't think it matters)
Other symptom is volt gauge drops from about 14v to 12v when headlights are on (engine running).
Sounds like a compromised connection in the main power circuit (including return side). Did you use 1 ga. for your main battery cables? Also the stock ground attachment to the body is inadequate. Those are the sort of places I'd look.
mstemp
Could it not be as simple as a failing regulator? When mine started to go the fan would drop me down to 12 volts. Soon as it switched off, I was back at 14.5v.
Jim - Battery leads (positive & negative) are either 1/0 or 2/0.  Both run from the battery to the engine bay - positive to the starter; negative to the stud on the frame rail near the starter.  From there, I have a braided strap to the block and a few 10Ga grounds - one to the dash area where anything in the cabin gets grounded and one each goes to my headlight & fan relays.  I also have a braided strap going from my trans tail shaft to the trans cross member.  Net, everything is tied to the battery not relying on chassis for ground.
Mike -- Hmmmm... I don't have a voltage regulator at all.  Not sure I need one with my autometer gauges, but will check.
I have two other electrical gremlins -- one might be related; other I'm pretty sure isn't.
In addition to my headlights causing volt meter to drop to about 12.5V & slightly raise both water temp & oil pressure gauges,
a) my speedo needle goes whacky sometimes.  It quickly bounces up to about 60-85mph (about 2/3 of the dial sweep) & then comes back down just as fast.  Sometimes it bounces around a little as it goes up & down.  Only happens at idle & have only seen it done after coming to a stop (e.g., haven't seen it do it if I start the car & just idle and never any oddities when moving).  I've always assumed this was a ground problem but it never annoyed me enough to chase it.
b) I have an LED wired to the +12v side of my fan relay to let me know when it comes on.  But, the LED comes on sometimes when I'm driving even when the fan isn't on.  I'm pretty sure this one is simply the fan spinning from air flow & generating enough electricity to backfeed & light up the LED.  I've thought about adding a diode but haven't taken the time to figure out what diode specs I'd need or how to wire it up.
Rob,
You are thinking stabilizer. Mike said regulator. I know you know there is one in your alternator.
If all connections are good & the belt is not too loose, then I'm with Mike.  The alternator is suspect. It can't supply what you are asking of it. Possibly bad regulator or bad diode in the rectifier.
You're right, I was thinking stabilizer.
Charles
Rob,
What wattage head lights are you running? I just upgraded to 80/100 and am seeing a slow drop in battery voltage. Me thinks it going to call for larger alternator to battery conductor. I am going to increase the wire size for grins
The bouncing gauges could be an indication off loose connection.
Hey Rob,
I'm guessing a voltage drop problem somewhere.
Your gauges work on a voltage differential. They don't really care ( within reason ) what the voltage is, they read the difference between the gauge and the sender.
So dig out your volt meter and start checking. I'd start at the battery and work my way forward. Do it with the car running and have someone turning the lights on and off. If you don't have help, wire up a flasher (hd12) to the headlight relay. And if idling for a long period is a problem. Hook up a battery charger to the alternator to mimic a running engine.
Ground and power between the engine block and the dash need to be rock solid. 0 voltage drop is ideal 0.1 would be max for good gauge operation.
Your bouncing speedo is probably a clearance problem at the sensor. If the clearance between the sensor and the reluctor is too great.
You end up with the pickup trying to read two teeth at the same time while stopped. Add in a little engine vibration and you end up with a ghost speed signal at rest. Hall sensor pickups are less likely to suffer but still do from time to time. You could also have an EMF problem but that would manifest itself at any time not just when stopped.
The LED problem very likely is the fan motor powering it up. Why not move it to the 85/86 side of the relay rather than the 30/87 terminals. No diode required.
Live like you mean it.
tr8todd
I thought all british cars did that.
Happy Cinco De Mayo!
British vehicles really do have rather eccentric gauges.
But most are adjustable and can be fine tuned to any environment. Even if they shouldn't have to be!
The nice thing is that they are relatively insensitive to electrical interference.
So they end up being more accurate than you would think.
But they are British so you are constantly on edge, which is probably prudent.
So they are doing their job which is making you pay attention to the engine ,Right?
Fred sez "I'm guessing a voltage drop problem somewhere. "
Remember that clinic that Max Fulton did in the parking lot at Indy last year? He was measuring voltage drop.
http://www.fluke.com/fluke/uses/comunidad/fluke-news-plus/articlecategories/electrical/diagnosevoltdrop
http://www.aa1car.com/library/voltage_drop_testing.htm
Yeah, I remember.  Not looking forward to tracking it down though.  With the fuse box mounted behind the dash, there's a lot of wire back there!  Verifying the drop will be easy.  Finding out where/why probably won't.
