Alternator design exercise
Started by BlownMGB-V8, July 26, 2014, 04:46:19 PM
Sadly, that stator has left the building.
The rotor size is pretty standard for a Bosch alternator so shouldn't be too difficult to find a stator that would fit.
There's a lot of meat there so you could turn it down to fit if needed.
A bit more info:
The Bosch rotor would have to be cut down close to .300" (8mm) to run inside the Delco S10 field coil, probably inadvisable. The Bosch unit is simply massive by comparison, and against a Denso rotor? That looks like a toy. It's also about twice as deep as the S10. I didn't measure it but it makes me wonder if there might not be a smaller version of that Bosch unit that would be more suitable for our use?
Also, the Bosch is a 14 pole rotor where Delco, Denso, and Ford are 12 pole so the field windings would not work anyway. Perhaps that is a function of the larger diameter.
The Stator doesn't care how many poles that the rotor has Jim. It's actually to your advantage to have more as it makes the stator think that the alternator is running faster than it is. That allows more charge at lower rpm's.
That rotor is pretty stout so taking 8mm off of it shouldn't be a problem. I can't remember it's actual diameter, but if you could measure it for me I'll check my stash of alternators for a stator that is close.
I measure it at 112mm or 4.380" diameter. The GM's seem to run close to 1/8" clearance on the diameter, which seems like a lot to me. My concern about cutting it down was more about losing magnetic flux (because or the reinforcing ring) than strength, I'm sure it's plenty strong.
About the pole number, yeah, I do think it makes a difference on the count, or at least can maybe depending on how the stator is wound. Normally I think the stator has three times the number of poles as the rotor  so each winding lines up with a + or - pole on each winding at the same time so that the voltages add. Otherwise I think the poles on the stator would be fighting each other.
But there could be other ways to wind it and I'm no authority.
Jim, in the theoretical world the pole count of the rotor vs the pole count of the stator does matter.
In the real world it's a different story. If the rotor poles matched the stator poles the alternator would howl like a siren. And break down the winding's very quickly. Even when mismatched the alternator is still very noisy. That's also why the GM alt's, as well as others, have such a large clearance. Less engineering required to keep it quiet.
So the fix is to taper the rotor poles so that engagement of the two is gradual.
It's not perfect but this reduces noise and vibration under load. And has the advantage of increasing the average efficiency.
Albeit at the expense of peak efficiency. A lot of which can be reclaimed with a lesser clearance.
I agree that the reinforcing ring is a deficiency, but a necessary one as it joins the two forged sections.
I think that the massively increased field coil power more than makes up for that shortcoming though.
I'll check through my carefully archived vintage automotive parts supply  (junk pile) this weekend to see what might fit that rotor better.
I found a bunch of stators that will fit for you Jim.
The easiest one to find is the mid 90's and newer bosch 120amp alternator. It came standard on quite a few European cars. BMW, VW, Audi, Volvo etc.
Should be an easy find at a wrecker.
Cool.
I'm still going to be tied up on the 3D machine for awhile but I'll get back to it as soon as I can.
