5 Lug Wheels
Started by rsdgeorge, February 07, 2014, 09:48:55 AM
rsdgeorge
First time posting and I am sure this has been discussed ad nauseum. I am in the process of a 5.0 conversion and would like a little more tire. I want to go to 5 lugs and 15-16 inch wheels. What is the best way ti do this? Stock front and rear for now.
rsdgeorge
There are some nice 4 lug Mustang rims available but they are 4x108 bolt pattern. How difficult would it be to change the bolt pattern?
63BlueMGB
Please review this thread with regards to the 5 lug front hub conversion. Alot more options with 5 lug, It really helped with my conversion.
http://forum.britishv8.org/read.php?7,17265,17373
tr8todd
What kind of car?  I did a 5 lug on the TR8 because it solved more problems for less money than keeping it stock.  TR8 bolt pattern wheels are few and expensive in between.  Ford 5 lug are cheap and everywhere.  TR8 uses tiny front wheel bearings.  TR8 rear ends as a rule, should automatically be replaced with a Ford limited slip disc brake rear end.  So take all that into consideration, and I kept the ford bolt pattern in the rear and swapped in SD1 front redrilled uprights and hubs.  How you do this is going to depend on what kind of car you are building.
codyrw12
I just got VTO classic 8s in 16x8 for my widebody BGT with 65 mustang front hub and a 8.8 rear
Hey Cody, Car looks great! Is that Dave's (Preform Resources) classic Sebring front valance?
codyrw12
Yep it's the speedster widebody with Sebring front
Grant70B
I used 1972 Chevelle hubs brought off of ebay.  Same bearings as the MG spindle.  Just machined some off the inner side to match the MG bearing spacing.  Then machined the GM seal lip to match the MG seal.  5 lug 4.75 spacing to go with my cut down s10 rear end.  Hope this helps
flyinlow
is there enough material to redrill the flanges?
No, If you look at the MGB front hub there is a dual bolt pattern for wheel and disk brake. The wire wheel rear hub can have the spindle cut off and redrilled for 5 lug. 4x4.5 is same circle as 5x4.5. Reuse one lug hole and 2 holes are close but works fine. MGC hubs for bolt on wheels are 5x4.75 Chevy pattern but rare over here.  I have seen them on UK Ebay. It is fairly easy to convert to American Chevy or Ford hubs in front and use American matching narrowed rear. If you do a search on here and Mgexperience, there are lots of ways.
