WAG on how much paint I will need.
Started by lars49, April 21, 2013, 01:56:40 PM
lars49
How much coverage can I expect from a QT of paint?  I'm  looking at using Southern Polyurethanes.  I'm going to call them next week, but I'd like some feedback on your experiences.
You will need more than a quart unless you are just doing a few panels or one end of the car maybe. I buy a gallon, but if you are doing everything, top, bottom, inside and out even that may not be enough.
Preform Resources
Jim is right, why take a chance on not having enough,, ironically the gallon price is cheaper per quart (usually) but you don't get a full gallon either (usually). Buying a quart here and there could result in a mismatch(poor mixing) and you will play hell trying to get them to correct any mistakes on anyones part.
Dave
BWA
You will be able to easily paint the entire car with 3 quarts of paint.  If you are planning on having the car finished with clearcoat you can get by with 2 good coats of base coat.  If you are not going  with clearcoat then you should go with 3 good coats of base coat.
Byron
lars49
Thanks guys.  It's an MGB-LE and I need to do the exterior.
The Florida and Colorado sun has completely oxidized  the exterior, the undercarriage is fine, the tub floors need done.  .I'm going with a black base coat/clear coat.  I found a local fellow that will cut me a stencil for the stripes so they can be painted instead of being appliqued.    The engine compartment will be a dark gray just so I can get some light in there.
This gives me an idea of what I need to order.  I wasn't thinking of ordering a single quart, just trying to get and idea on how many square feet it would cover.
