New guy on the block
Started by tr6lt1, May 01, 2008, 04:42:11 AM
tr6lt1
This weekend I finished the rear cross member. I used a piece of 2 ¾ x 2 ¾ x ¼  square tubing because that's what I had in the shop at the time. I still plan on using 1 /12x 3x .120 rectangular tubing for the frame stub. I also used 2" long left over pieces of the lower control arm tubing to make my bushing mount. I had a set of 1969 Camaro Poly rear spring bushings that fit the tubing perfectly, so I used them for the main cross member isolators. I will use the Chevy truck bushings for the lower control arm mount struts instead. I used 3/8" plate for the gussets and the third member plate as well as the lower control arm "wishbone" braces. The gussets between the third member and cross member already have the 4 degree angle in them that these jag rear ends have built into the tops of the thirdmember. Here are some picks......
It looks very strong Frank, nice dogbones btw. Good access to the diff mounting bolts too. Do you think you'll use both sets of springs? Seems I heard Cobras only used one set because they were so much lighter than the donor car. We were planning to run coil-overs on the Roadmaster but haven't bought them yet. Here's the link if you're interested in seeing how we're doing on that: http://forum.britishv8.org/read.php?2,166,page=17 bottom of the page.
tr6lt1
Jim, I will try all four shocks and if they turn out to be too heavy I will try just two...I am on a tight budget for this project and after market coil overs are not an option............I read the article posted on your page about the axles turning while welding. I first spot welded the tubes to the axlestubs and then clamped them down to a surface plate on the machined sufaces of the u-joint retainers. They did not move and were perfectly straight after welding.
