New to the gallery: Merv's E-type!
Started by Moderator, January 14, 2011, 02:36:10 AM
A lot of you guys know and love Merv. He's that handsome gentleman at our annual meets who has enough self confidence to make a pink t-shirt look good, sortof. And probably most of you know Merv's handsome <a href="http://www.britishv8.org/MG/MervHagen2.htm">Ford Boss 302 powered MGB</a>. (Boss 302 engines combined the strength of the Windsor bottom end with the better breathing of Cleveland-style cylinder heads.) Now check out Merv's beautiful Jaguar E-type!
Link: <a href="http://www.britishv8.org/Other/MervHagen-Jaguar.htm">Merv Hagen's 1973 Jaguar Series III E-Type with Ford Windsor V8 (351cid)</a>
Teaser photo:
jellison
Different and looks nicely done.
Has it got alloy head to get some of that weight out (V12 with the SOHC all alloy and pretty light).
Good idea on getting the Auto pulled out and a proper 4 speeder popped in.
Good luck and Enjoy.
Merv
Jon, Jaguar V12 weighs in at around 680 LB and even with Iron heads 351 Ford est. weight is around 525 LB.
I am not exactly sure if the Manual Trans is more efficient but I agree that it is sure a lot more FUN.
Still just trying to get all systems working as they should, before any major modifications. But still having FUN and it is a great way to keep Cabin Fever away during our Chicago winters.
Merv
slow_M
Posted by: Moderator
...Boss 302 engines combined the strength of the Windsor bottom end with the better breathing of Cleveland-style cylinder heads...
                       _____________________________________________________________
Curtis,
the Boss 302 has, by definition, a four bolt main bottom end. The "regular" production Windsor block has two bolt mains. That's why this racing version was able to turn as high as it did. In addition, the 5/16" rod bolts are a weakness on the Windsor bottom end and have to be upgraded for serious high performance use.
B.
Merv,
Nice cars. The E should have sweet handling, when you're done. 2.88 should give it damn long legs. Sorry I didn't get to see your toys when I lived out that way.
B.
