This is our new pulley under drive kit for the reverse water pump 3.4 V6 engine.
This is a complete.
I will have a price as soon as I get the bill from the water pump pulley and idler, should be in about 2-3 weeks.
Just wanted to give you a look of what is coming soon. All of the brackets are aluminum, pulleys are CNC machine from a block of aluminum, brackets are water cut and all of the bolts are 8 grade.
We will also have an idler /alternator kit for the reverse water pump so that the stock pulleys can be use, kit comes also complete.
