General Category => MG Sports Cars => Topic started by: BlownMGB-V8 on March 27, 2009, 10:26:10 PM
Title: True bolt-in independent rear suspension
Post by: BlownMGB-V8 on March 27, 2009, 10:26:10 PM
I wanted to post photos of both of these IRS units together in their own thread, especially since the info in the 340 and Roadmaster threads will eventually get buried in the mass of other information. This first unit is for the Roadmaster. It has a 3.08 gearset, urethane bushings in the forward crossbar, and will bolt into the MGB without any modification of the body whatsoever, including the battery boxes and the bump stop "humps" but may need custom wheels to clear the stock bodywork.
This next one was built to go in my '71 Roadster. It has rubber mounts, 3.54 gears and a few other more subtle differences.
Title: Re: True bolt-in independent rear suspension
Post by: rficalora on March 27, 2009, 11:26:36 PM
They do look great Jim!
Post by: itsawindupuk on April 09, 2009, 01:06:38 PM
thats brilliant!! how did you make this, obviously its jaguar components, im looking to upgrade my MG's rear end as its fairly standard, and this looks too good!
Post by: BlownMGB-V8 on April 10, 2009, 12:30:00 AM
How did I make it? Mostly grit and determination I'm afraid, but the details are in the 340 and the Roadmaster threads.
I'm in the process of installing the second unit in my roadster and I'm afraid they need slight revisions as currently some minor tweaking of the battery boxes is necessary in order for the upper shock mount bolts to be removable, and the gas tank has to be dented in to clear the rear torque straps. Those could perhaps be left off, but I think some sort of torque link there is a good idea. Of course there are other ways of doing that.
Post by: theonlyiceman53 on April 10, 2009, 06:37:22 PM
Hey,
Nice job on the fabbing.  They really make a difference on the ride quality.   I used the stock Bilstiens and cutdown late model springs and the spring rate worked out good.  Not sure how but.............    I cut away the stock battery boxes and put the battery in the trunk as it made life much easier that way.  Off setting the gas tank also worked out well.
Great Job,
Post by: BlownMGB-V8 on April 10, 2009, 07:03:08 PM
The roadster won't have the tank offset since it has side pipes but the GT probably will, and if there's any more room to move it rearward we may do that too as 1/2 to 3/4" will make a difference.
Post by: Mr. T on April 10, 2009, 10:01:14 PM
Jim, What's the weight of that setup?
Post by: Mr. T on April 10, 2009, 10:05:49 PM
Oops, just saw your other post on weight.
Post by: BlownMGB-V8 on April 11, 2009, 01:20:44 PM
Right, 90 lbs heavier than stock but with tubular half shafts and aftermarket lower control arms that can be reduced to 50 or less. It's a great option with an iron block engine such as the Ford or Buick, as it easily will balance the extra weight. Many combinations are possible. Looking at vehicle weights, it it common to see a difference between front and rear tire weights of 50 lbs (for example 575 front, 525 rear) so an extra 90 lbs on the rear balances the car almost perfectly. Of course, it is possible to make the car heavier in the rear. A combination of Rover engine, Ted's front suspension and the Jag IRS could do (especially with a full tank and gear in the trunk! ;-) that but in that case one would want to go with the lighter components as well to minimize the difference.
Post by: tcmgb on April 13, 2009, 10:12:49 PM
have you thought about making the custom cradle for sale? Looking for the cradle only.
Post by: djw090 on April 14, 2009, 04:05:52 AM
Jim,
Do you have a picture from underneath. I guess the lower inboard pivots attach to the diff in some way.
Is it correct to assume this set up only mounts to the body at the droop strap mounting, the damper mounting and the front spring eye mounting?
David
Post by: Bill Young on April 14, 2009, 08:03:15 AM
Jim, the overall weight is higher, but what about the unsprung weight? I would think that you would have a major reduction there with the IRS.
Post by: BlownMGB-V8 on April 14, 2009, 11:38:07 PM
Yes the unsprung weight has been very considerably reduced. The brakes and diff are  chassis mounted of course, leaving only the control arms, half shafts, uprights and spindles as unsprung weight and half of the weight of the control arms and half shafts is deducted as well since they are mounted to the chassis on the inside. The weight of the coil-over units is pretty minimal as well, nearly half of that also being deducted. So where the stock suspension has about 201 lbs of unsprung weight, the Jag IRS has about 50 to 75 lbs. depending on what components you use. I'm sorry, that's about as close as I can get right now as I'd have to disassemble something to get a more accurate figure.
Jim as far as selling the cradle, I wouldn't be opposed to that but it involves a fair number of pieces and has to be made to match the control arm lengths. It's something we could discuss if you want to send me a PM.
David, you are correct, the inner pivots use the stock Jaguar inner pivot brackets, and the completed unit attaches just like you said.
Post by: djw090 on April 15, 2009, 06:15:43 AM
Thanks for the reply Jim. Did you ever think of using the later Jag rear end from the XJ40 as a base?
David
Post by: BlownMGB-V8 on April 15, 2009, 09:26:36 AM
Haven't considered it David, in fact I've not even had a real good chance to look one over closely though I do know that they are considerably different and I'm not real sure how difficult they would be to narrow. Aren't the brakes on those outboard as well? I realize some folks don't mind that weight penalty, it makes little difference in a 4000 lb car. But in am MG it would be noticeable.
Post by: classic conversions on April 15, 2009, 02:34:59 PM
I question the unsprung weight, I do not think is less, even if the calipers are  inboard.
But street use unspring weight is minimal signifcance and it is overshadow by the IRS.
Tuning an IRS is complex and careful thinking must be applied.
I am not against it, it is a reality of the IRS system.
I have a qusetion mainly due to the picture is not clear, does the driveline (driveahsft) clear the front brace?
Post by: BlownMGB-V8 on April 15, 2009, 06:30:23 PM
Well Bill, I just don't know what to think....
But that's OK, at some point I'll get some actual weights for you. For now about all I can think of to say is take another look at it. I'm really confused as to how you could possibly have drawn those conclusions... you're not yanking my chain are you?
Anyway, yes the driveshaft will clear the front brace quite easily with plenty of room to spare. There's not much in the way of adjustments. You can change the shims at the rotors to vary the camber some and tune the coil-overs and that's about it. Everything else has a fixed relationship. There's a slight amount of toe built in and it isn't adjustable, obviously no caster to be concerned with. The camber change is dictated entirely by the LCA and half shaft along with the vertical distance between the pivot pairs both inboard and outboard and we are a little shorter on the control arms than the XKE, by a little over an inch. I can't see that being much of a big deal, especially given the widespread use of this suspension in modified vehicles in a tremendous variety of narrowed configurations. For an IRS it couldn't get much easier.
Post by: classic conversions on April 15, 2009, 11:28:28 PM
My MISTAKE !!! JIM.
 What I meant to say is that is heavier than a straight axle, but for street use is..... and I guess that was already discuss, so I was just putting my 1/2 cent opinion, sorry for that.
It looks great. Are you using a single coil over on each side? What is the total width from hub to hub. The XKE is only 1/4" total wider than the MGB. But hey I could be mistaken.
Sorry !!! if I steped on one of you toes.
Post by: BlownMGB-V8 on April 15, 2009, 11:53:56 PM
Oh that's OK, I just figured you were having a little too much fun, ;-) You've helped me though because I had to re-figure the width as I'd looked at the wrong numbers. The XJ6 is 61-3/4" from hub to hub. We narrowed it 5-1/4 so 56-1/2" which is wider than the unit in the 3.8S by 1/2" and wider than the XKE by 3-1/4". But 57-1/2 to 58" would work much better with Corvette wheels. This is only possible using 16 or 17" wheels having a deep backspacing of up to 6-1/2" edit: (or up to 7-1/4" with the extra width) and flared fenders, but it gives excellent suspension geometry as well as a full 8" of vertical suspension travel, practically unheard of in this type of car. I used single coil overs, QA1's and 225lb springs on my convertible, 250 on the GT. The 225's may be a bit on the soft side, but if too much I'll just stiffen up the damping a bit on compression. I also added bump stops on both just in case.
Post by: BlownMGB-V8 on April 17, 2009, 12:58:50 PM
Now for the benefit of those who really would like to have better numbers for the unsprung weight,... I did some testing. Put the flat plate on my floor jack, the shipping scales on that and placed it under the bottom pivot of the upright after disconnecting the bottom of the coil-over. After much raising, lowering, jiggling and tapping I came up with a weight of 35 lbs. Double that (70), add the weight of one coil-over unit (about 5 lbs probably, maybe a little more) and you have the total unsprung weight using the stock shortened LCA's and  stock half shafts sleeved with heavy wall tubing. I forget the exact dimensions but if you're that curious you can find it in the 340 thread. Those four pieces are right heavy, so when I said I thought 25 lbs or so could be dropped, that's only 6 lbs off each piece, easily bringing the total unsprung weight down to 50 lbs and maybe less. Add about 25 lbs per corner for a good light wheel/tire combo and you're at 50 lbs per corner. Not bad. Of course the front would be less but it isn't providing power.
So there you have it. Pretty close to the earlier guess, and of course I'm not going to claim that this was the most accurate method possible, but I would say it's within +- 5 lbs at the worst. And that's a whole lot better than stock. Stock rear unsprung weight is about 8-3/8 % of the car's weight. Here we're at 3-1/8 %. Or to put it another way, 1/12th versus 1/32nd and we could drop that to about 1/50th. I'd certainly expect that to be a noticeable difference.
What happens when we add the tires and wheels? Well using the earlier weight of 25 lbs each we're over 1/10th versus 1/19th so we've cut it in half, actually better than that. Those of you that have played with light weight wheels and tires will recognize this as a very significant advantage.
Post by: MGBV8 on April 17, 2009, 09:50:45 PM
"Add about 25 lbs per corner for a good light wheel/tire combo"
Good Luck with that!  ;)
Post by: BlownMGB-V8 on April 19, 2009, 12:42:33 AM
I thought you might have some insights on that Carl. I know there are 11 lb wheels available, not sure about the tires.
jim
Post by: rficalora on April 19, 2009, 09:18:39 AM
This thread on an integra BBS has tire weights of a bunch of tires.  Based on this and assuming something wider than 225's (which is as wide as I saw in their list) says the tires will weigh somewhere in the upper 20s to upper 30's per tire.
http://www.team-integra.net/forum/display_topic_threads.asp?ForumID=17&TopicID=116506&PagePosition=1
Post by: MGBV8 on April 19, 2009, 10:00:46 AM
I have my doubts about the durability of an 11 pound wheel that is mainly used on the street.
The Toyos that I like tend to be lighter than real street tires & anything in a 17" size is going to weigh 24-25 lbs. just for the tire.  As Rob pointed out, most realistic street rubber will be heavier.
Did we ever decide on a wheel/tire size?
Post by: MGBV8 on April 19, 2009, 11:01:57 AM
A 255/50-16 tire will weigh 27-30 lbs. The 16 X 7, 7.5, or 8" wheel may range from 10-30+ lbs.  One we can afford that will hold up, probably 20-25 lbs.
So, I think 50 lbs per corner is more realistic.
Post by: BlownMGB-V8 on April 19, 2009, 11:41:35 AM
Edit: (..ever decide on a tire?) Not really. The choice is pretty wide open though since the wheelwells are cut out on the Roadmaster. I've found 315's will work on mine with the right wheels, something with about 6-1/2" of backspacing. And they were cheap. On the GT we're only limited by a maximum tire diameter of about 26" and that roughly translates to a 335/35-17 . I think we had decided a 275 was a good option awhile back. As for the wheels, realistically they will probably be heavier than that. My old 14" Centerlines are 11 lbs and have been plenty durable and strong, but 17" will probably be heavier. There's a lot of variation in wheel weights though and almost nobody publishes weights, which makes it real hard to find a light wheel. You have to research the construction methods and carefully read the claims for "strongest and lightest" and even that's not enough. But, I'm almost ready to call Greg and I have high hopes for his new design if he's still doing it.  As for the tires, maybe that is where I got that 25 lb figure Carl, or maybe it was from weighing one of my old threadbare TA's. I know there's a lot of variation in tire weights too and those seem pretty light. Doesn't it seem a little odd that an old 50 series tire on an old-tech rim would be lighter than a 35 series on a modern rim? Aren't we moving backwards a little here? But, no matter. In the end a guy has to run what he can afford, can obtain, and works for him and our choices will all be different.
So on the bottom line, if the rims are 15 lbs and the tires are 35 then a rework of the unsprung weight proportions gives different numbers. Going through it again, just from memory, figuring 50 lbs for wheel and tire and half the 201# stock unsprung weight or a total of 151# per rear wheel and a 2400# car I come up with 15.9 as a ratio for one wheel or 7.94 for both. Then with the same 50# plus 35# for 85# per wheel I get 28.2 and 14.1, which I think is still going to be enough to feel the difference. It won't affect acceleration and braking the way lighter wheels and tires will, but it will affect ride and roadholding, perhaps profoundly. Lets not forget that 8" of vertical travel. If you drive rough roads and hills very much that is going to really, really get noticed. And that is dropping a whopping 66 pounds per wheel! How much does it cost to lose about 20 lbs total with a Currie alloy center housing for the 8" Ford axle? We're dropping over 3 times that on each side. That makes the cost analysis begin to look a whole lot more attractive, and of course there's a whole lot more to it than that.
I think we are going to be pleasantly surprised by the ride when we get the Roadmaster going. But is that a good thing? I'm not so sure. It may start rumors and speculation concerning the other end of the car.
