Appreciate any advice on the "proper" clearance between crank harmonic damper and steering rack when fitting 215 V8 in MGB.
Issue: I'm test fitting the motor now and finding the crank damper does not fall ahead of the steering rack but will just contact it if I fully lower the motor in the frame mount slots.
I could achieve vertical clearance by adding shims to the rubber pads but this does not seem correct? I would hope the damper would clear ahead of the steering rack vs. above it...
Details: 1977 MGB all stock no mods. Rebuilt Olds 215V8 with MGB conversion brackets on block. Conversion brackets do not allow lateral fore-aft movement. Late MGB rubber mounting pads between block and frame mounts in original factory location. Rubber mounts positioned with the securing bolt in the low position.
