Buick 215 engine block for sale.
Crank is there and rotates as it should. Never removed the caps. Camshaft is there and also rotates as it should.
Engine is a J code: 1961.
Bores look good.
$300.00 local pickup in Detroit metro area.
I also have a Rover 3500 block with crank and main caps for sale. $300.
Also, many other Buick 215 parts!
Send me a message for questions / contact info. Thanks.
Correction: J code is 1963.
I had a question on the bores. The buick 215 block has 30 over bores.
The rover 3500 block has stock bores.
"Correction: J code is 1963"
JM or JN?
https://www.britishv8.org/Articles/GM-215-Engine-Identification.htm
am looking for a serpentine belt setup off of a Rover.
specifically require crank pulley, tensioner/pulley, power steering and alternator. AC is optional.
Steve,
Lots of spare parts? Do you have a Buick Bellhousing available? Will you ship or pickup only?
Roger B
