General Category => Engine, Transmission, & Rear Axle assy. => Topic started by: relative4 on February 07, 2009, 05:27:37 PM
Title: Timing cover seal
Post by: relative4 on February 07, 2009, 05:27:37 PM
The timing cover seal on my '80 SD1 V8 needs replacing.  The standard auto parts chains sell Felpro part 15200 as the replacement, but it's a full 1/8" too wide to fit the timing cover.  Can anyone direct me to the right seal?
Post by: relative4 on February 07, 2009, 06:40:21 PM
 -- moved topic --
Title: Re: Timing cover seal
Post by: Bruce Mills on February 07, 2009, 08:45:48 PM
While searching for head gaskets last week I discovered that the gaskets are the same for all the following.
Gaskets for Buick Skylark 61-63
Buick Special Deluxe 61-63
Buick Special 61-63
Rover 3500S 69-71
MG MGB V8 75-77
MG MGB MK1V 75-77
Triumph TR8 80-81
According to D&D
"10.00 13001 Timing Cover Gaskets – For all engines, includes rope seal"
I used the following for my Rover 3.5
Timing Cover Gasket set Fel TCS 13001
Water Pump Gasket Fel 129961
Hope it helps
Bruce
Post by: relative4 on February 07, 2009, 10:53:28 PM
Thanks, I think I've found a couple of good alternatives to the rope seal that comes with that kit.  Part ERC7987 from Moss Motors should do the job, and D&D sells part 49532 from AutoPart International; I'll check those out.  VB's item 5-805 is much lower priced, so I suspect it may be a rope seal.
Post by: Richl705 on February 08, 2009, 10:35:51 PM
Bruce,
This is really good information.  I think it would be neat if there was a place where all this info came together.  There have been many times when I found that a part for an MGA, which was very high priced, was available more cheaply for a triumph, and it was the same part.
