General Category => Engine, Transmission, & Rear Axle assy. => Topic started by: ag1234 on February 17, 2024, 01:33:56 PM
Title: Alternative RV8 pistons ?
Post by: ag1234 on February 17, 2024, 01:33:56 PM
Perhaps not  original RV8 pistons ?  Perhaps some Toyota 3.7" bore, V8 ?
        Onward,  Art.
Title: Re: Alternative RV8 pistons ?
Post by: RDMG on February 27, 2024, 02:26:55 PM
I found Toyota pistons for the 2rz-fe  4-cylinder engine from early 1990s Tacomas.  they're a decent option if you're using a larger combustion chamber head like Buick 300.
3.74" (95mm) diameter, 24mm pins (same as RV8).  NPR makes a set of 4 for $80-ish, you can buy off-brands on eBay for less.
I have a set of 8 oversize pistons (95.5mm I think) if you want them.
Post by: BlownMGB-V8 on February 28, 2024, 10:34:47 AM
Cast?
Compression height?
Dish?
Post by: MGBV8 on February 28, 2024, 11:56:21 AM
Toyota 2RZ-FE?  That engine was in production from 1995-2004 for the Tacoma.
Wiseco Forged Pistons Toyota Tacoma 95-03 95mm STD 2RZFE 8.8:1 -10cc K642M95
Compression Height   1.398" / 35.5mm
Dave R brought up using Toyota pistons back in 2018.
http://forum.britishv8.org/read.php?6,63331
Post by: mgb260 on February 28, 2024, 12:10:57 PM
Not zero deck, with that small dish, probably .030-.040 down. The stock size is .040 over Rover 4.0/4.6. Very inexpensive. I think Dave had 10 to 1 with the 300 heads.
Post by: RDMG on February 29, 2024, 09:00:38 PM
Hard to believe it's been 6(!) years!
The Covid pandemic didn't do my project any favors.  I have an RV8 block with the low-cost Chevy 305 top hat liners pressed in but not bored/honed, a set of tricked out 300 aluminum heads with oversized ferrea valves and z28 springs, a 4bbl 215 intake, a "fast road" 215 cam, an early Land Rover oil pan, and a few different front covers.  Also a 4.6L rv8 crank, an aluminum flywheel, the Toyota pistons, and some lightweight piston pins. Sadly, they're all collecting dust.
I am in desperate need of a machine shop to bore/hone/deck the block and dynamically balance the rotating mass, but that's another topic...
I'll dig up the specs I found for the factory 2rz-fe pistons, if I recall, the comp height was the same as the wiseco pistons above, but the dish was a bit smaller.  From what I saw on the web, the Toyota guys like to turbo/supercharge their engines, and the stock 2rz pistons hold up pretty well when they do.
I'm reasonably confident that the piston/heads combo will work, but it seems every commercial machinist within 100 miles of me thinks I have two heads...
Post by: ag1234 on March 01, 2024, 09:51:44 AM
Dave, I believe the 215 intake manifold will be a restriction to those 300 heads. Though not the best design, the Offy single-plane will port easy to match the 300 heads.
        Good Luck,  Art.
