General Category => Engine, Transmission, & Rear Axle assy. => Topic started by: 302GT on February 15, 2024, 05:20:26 PM
Title: TKX transmission
Post by: 302GT on February 15, 2024, 05:20:26 PM
I put a TKX transmission in my car as a T-5 replacement; there was nothing wrong with the T-5 but I wanted to try something that was state-of-the-art. The TKX fit well but it required a different TKX specific bell housing. The transmission mounting pad was in the same place as the T-5 pad, but it dropped the transmission an inch lower so I had to make a 1 inch spacer to preserve the drive shaft angle. The optional shifter had enough locator options to finally get the shift lever centered in the MGB tunnel.
The shift action is excellent, noticeably lighter and faster than the T-5. The ratios also seem slightly better (I got the wide ratio Ford version).
Unfortunately, the transmission is noisy. There is a rattle/vibration below about 2200 rpm and an occasional loud buzz from the shifter. The rattle was very similar to one I had in the T-5 and which I fixed by increasing the input bearing preload. This could be the problem with the TKX, but I need to remove the transmission to check this. I also called Silver Sport Transmission (a Tremac distributor) and they said noise was normal, then admitted it may not be normal, but was not a sign of any mechanical distress. One suggestion was to hit the input shaft with a large hammer to better seat the rear input shaft bearing, which might reduce the shifter rattle, and they also admitted the input bearing preload might not be right. Another suggestion was to drive at least 500 miles to break-in the transmission and then the noise would go away. I did not contact Tremac directly yet ...
 An internet search showed that some people experienced no noise, but others had problems similar to mine. It was not clear if Tremac would actually fix a noisy transmission under warranty. Sometimes they did but were not always successful, and it generally took several months.
I can easily adjust the input shaft preload and that might take care of everything but it takes me about 20 hours to remove and replace the engine/transmission and I do not feel like doing this very soon.
Title: Re: TKX transmission
Post by: Airwreckc on February 15, 2024, 05:40:37 PM
That's a really interesting transmission.  I had a TR-3650 built to significantly improved specs for my MGB V8 project--of course, this transmission didn't exist at the time.  The narrower case would certainly be a nice thing, as I'll likely have to widen my tunnel.  I guess the only thing I can hope is that mine shifts like butter (which is what I've been promised).
Post by: MGBV8 on February 16, 2024, 08:50:44 AM
You should be able to drop the trans without pulling the engine, Larry.
Post by: joe_padavano on February 16, 2024, 09:24:13 AM
The GM-spec TKX bolts to an Muncie/T10 bellhousing. Why did you need a "specific" one?
Post by: MGBV8 on February 16, 2024, 10:50:17 AM
Larry has a Ford V8, so his bell housing has that "other" pattern.   ;)
Post by: turbodave on February 18, 2024, 09:25:24 PM
Have you used an indicator and measured the run-out of the pilot diameter and the trans mounting face on the bell housing?
I have heard the TKX is significantly more sensitive to this than the T5 ever was, and creates noise and other issues.
Just because a bell fits an engine, doesn't mean it's properly aligned to that engine..
I have the T5 in my SD1, and would love a TKX, but the T5 is working out really well for me at this time.
Post by: ag1234 on May 13, 2024, 11:33:40 AM
Or is it...?  Maybe left field but have you run car, securely on jackstands ?  IOW, same rpm and gear ?  Why did previous trans vibrate at about same rpm ?
        Good Luck,  Art.
Post by: 302GT on June 06, 2024, 09:12:22 AM
I have maybe 1000 miles on the transmission and it is much quieter now. However, there is a loud buzz from the shift lever if I touch it before disengaging the clutch, and there is a very distinctive rattle at idle in neutral. Someone else here in WI just completed a Sebring replica MGB GT with a 540 hp Ford engine and TKX transmission. His complaint was that the transmission would not downshift to second without severe grinding but that after driving it for a while it works better, but not perfectly. The other gears work fine. It seems there are quality issues with the TKX (many comments on-line as well).
The T-5 I took out was totally quiet. However, it did make rattling noises at one point which I solved by increasing the preload on the input shaft bearing. I think this may still be a problem with my TKX.
Title: Re: TKX transmission update
Post by: 302GT on April 12, 2025, 10:23:26 AM
Now that I have a few thousand miles on the transmission, it is almost totally quiet. There is a minor buzzing sometimes when I touch the shift lever, otherwise no noise at all. Shifting is incredibly light and fast, far better than a T-5. Only problem is first to second is "notchy" when cold, but smooths out after about 2 miles. No Idea why the transmission should improve so much with use but I am very happy with it. The lesson is just be patient with it.
Post by: 88v8 on May 03, 2025, 10:32:05 AM
Good to hear.
A thinner lube may help with the notchiness when cold, but we don't really want to start a debate about oils....
