General Category => Engine, Transmission, & Rear Axle assy. => Topic started by: BlownMGB-V8 on December 08, 2022, 11:52:25 AM
Title: Adjustable rockers for the late Rover (rollers?)
Post by: BlownMGB-V8 on December 08, 2022, 11:52:25 AM
I'm just getting ready to machine the base plates for the paired rocker sets to go on my TA heads and was wondering if it might make sense to try and adapt those to the Rover heads as well. I know Volvo rockers have been used in the past as well as the Harland Sharp rockers and have been watching the discussion about the Olds heads but don't know how the rocker shaft sizes stack up. What's the latest thinking on this?
Title: Re: Adjustable rockers for the late Rover (rollers?)
Post by: mgb260 on December 08, 2022, 02:09:02 PM
JIm, set the rocker height at 1/2 lift for smaller wipe on the valve stem. Should be level with retainer so if you drew a line from center of roller through center of trunion. Rocker stand height determines this.
Post by: roverman on December 08, 2022, 02:54:19 PM
Closer to edge at start of lift ? Well maybe... Load on rocker/ push rod, is quite low compared to full lift.
        Art.
Post by: mgb260 on December 08, 2022, 03:22:00 PM
Art, Mid lift gives less wipe on the valve tip.
Post by: BlownMGB-V8 on December 08, 2022, 04:51:28 PM
Looked at the heads again, the rocker pairs are a no-go. The TA head has twice the number of bolts to hold the base plate down and the locations are better. The bolts would fail, it's been attempted before. Guess the full shaft rockers are the only option. Haven't looked at the Rover rockers yet to see if adjusters could be substituted for the hardened tips.
Post by: mgb260 on December 08, 2022, 04:54:30 PM
Jim, Maybe you could bore the rockers to fit original shafts?
Post by: BlownMGB-V8 on December 08, 2022, 08:59:52 PM
It's an interesting idea but those use a 9/16" shaft so that's going up something like 1/4"? Might be enough metal left, I'll have to look. Also have to get some suitable caged roller bearings but a good thought.
Post by: mgb260 on December 08, 2022, 09:04:23 PM
Jim, a lot of roller tip rockers just have a bronze bushing. I'd be tempted to just use the rocker itself and lube with Moly grease when installed.
Post by: BlownMGB-V8 on December 09, 2022, 12:21:26 PM
That's worth considering. Looks like the bearing OD is about 3/4" which means  bored/reamed to the shaft diameter would take out another .050-1/16" which would be acceptable. That means using the aluminum of the rocker as the bushing but these heads do have the pressure shaft oiling port and so do the 300 and 340 blocks so it's just a matter of making sure the head gaskets have the hole. Lots of engines used an aluminum or light alloy rocker with no bushing. It'll eventually wear out the rocker but will continue to work. So that would be one option, to modify a set of the paired rockers.
Another option would be to find individual rockers (right and left) for a larger shaft. It seems like there would be something out there that would work without too much fiddling.
Post by: mgb260 on December 09, 2022, 01:39:05 PM
Maybe big block Mopar. May be too wide and shaft is bigger at .875".
https://www.ebay.com/itm/203799801700?_trkparms=amclksrc%3DITM%26aid%3D1110006%26algo%3DHOMESPLICE.SIM%26ao%3D1%26asc%3D243940%26meid%3D252a141ef1b744838f6706b6653f155c%26pid%3D101195%26rk%3D3%26rkt%3D12%26sd%3D291747783501%26itm%3D203799801700%26pmt%3D1%26noa%3D0%26pg%3D2047675%26algv%3DSimplAMLv11WebTrimmedV3MskuAspectsV202110NoVariantSeedKnnRecallV1%26brand%3DSpeedmaster&_trksid=p2047675.c101195.m1851&amdata=cksum%3A203799801700252a141ef1b744838f6706b6653f155c%7Cenc%3AAQAHAAABMMFr2e4EmAnM%252ByHZkULYKDIJ4L66fOjNL0iupgt%252BzO1%252F3AE1t3mNirUYB96NktMCicMagiS6mbeTl0xquGODv9lxM3MNNZGQdS3t%252BD4PMdscuBHnCsDyNf7A0g6zeP84rIU31igMSAMO4xrcypOAhXxZ%252FEjZ4Id%252F595%252FePdI%252F9TMHbbbYwgA9aJka2yidFl8no06EHUxsqwb36HeFa82%252F3JJd6jPmiQenfWJMuwizsHK8TEp3MphE3BU4JOUEHfeB8F6Lg%252Byevr34uJ9PIJlQ4bZjMDIgLBdBnn8ODkiFK5OYmdHcx3Rn8ccadMgXyG5pYUL8DN9yO%252B1ODBC8IKz55YRXjGw2S7JGoqT5Qlpl%252FDJ3kHLjB94fMPvwI8Pc3UDh2NMV773Q1JjP1%252F1xYCwjKA%253D%7Campid%3APL_CLK%7Cclp%3A2047675&epid=15024466867
Post by: DiDueColpi on December 09, 2022, 04:23:51 PM
BB Mopar sadly won't work.
The body is far too wide at 1.560 inches.
You might get away with thinning them down but it would be sketchy for sure.
I have a good sized selection of roller tipped rockers from my quest for the perfect Rover replacement. Haven't found anything that makes me happy yet. None of the later performance rockers that I've seen use a needle bearing anymore. They all use a bushing or ride on the base metal that they are made from.
Post by: BlownMGB-V8 on December 09, 2022, 04:52:34 PM
Good to know Fred. I just checked the shafts on these heads and they are the .805" diameter mentioned earlier. I guess a plain bearing makes sense, from an oil pressure standpoint anyway.
These Procomp rockers I got in that paired chevy kit are .900" wide
Post by: mgb260 on December 10, 2022, 02:34:09 PM
Jim, how wide are the stock rockers?
Post by: BlownMGB-V8 on December 11, 2022, 12:33:28 PM
.840"
These are .060" wider so .030" removed from the side of the pedestal should put it in the same position, might not even need to do that much. Here's one that might be worth trying with the stock rocker shafts:
https://www.ebay.com/itm/291950967582?_trkparms=amclksrc%3DITM%26aid%3D1110006%26algo%3DHOMESPLICE.SIM%26ao%3D1%26asc%3D243456%26meid%3D621320a3a5c44d29ba3bcf8ca018a314%26pid%3D101195%26rk%3D5%26rkt%3D12%26sd%3D302145890374%26itm%3D291950967582%26pmt%3D1%26noa%3D0%26pg%3D2047675%26algv%3DSimplAMLv11WebTrimmedV3MskuAspectsV202110NoVariantSeedKnnRecallV1&_trksid=p2047675.c101195.m1851&amdata=cksum%3A291950967582621320a3a5c44d29ba3bcf8ca018a314%7Cenc%3AAQAHAAABIMFr2e4EmAnM%252ByHZkULYKDIJ4L66fOjNL0iupgt%252BzO1%252F3AE1t3mNirUYB96NktMCicMagiS6mbeTl0xquGODv9kqsZwPsUX3kUAsdmE%252BsVoh6oh4BPzPIvt3JmPzMzGGZX%252FcxprEbYmokvYnuElyN7wawtX%252Fae9tjvlrWbsNwE%252FWx5s4r2IO%252BElKcqWhT%252Bk0%252Fm0LzIQ8T8HC6Mm6c11TrcZkd1%252FdjdiFLl%252B%252BNPuXrFbk%252F1R6HZ8uq%252B2WbZ7n1DHNt83Dwv%252FPlSvhw%252FbETF6HIdnFfuliaBpqn%252FpWNE5vuGjeoqJRSHecVX7c24iJGZF%252Fsdu%252Bfb58Szc1Q68aOaRya8f4LoLgmqlGwCwAHM8RjlqoU0wPuMXPSFbwyF53roFXFQ%253D%253D%7Campid%3APL_CLK%7Cclp%3A2047675&epid=13035389890
They look similar to the kit I bought but you wouldn't be paying for the extra hardware that you wouldn't be using. A little hard to tell but it looks like they probably do have the left/right offset.
I think I might use the procomps I have on the Rover heads. The shaft bearings and clip were the cause of the reported failures and that would get rid of that. The TA heads have 1 stud per valve like chevy so this might be a better choice for them:
https://www.ebay.com/itm/301939904971?_trkparms=amclksrc%3DITM%26aid%3D1110006%26algo%3DHOMESPLICE.SIM%26ao%3D1%26asc%3D243456%26meid%3Dbc3aa05c012f454cb1993e40c74cf4e1%26pid%3D101195%26rk%3D3%26rkt%3D12%26sd%3D291950967582%26itm%3D301939904971%26pmt%3D1%26noa%3D0%26pg%3D2047675%26algv%3DSimplAMLv11WebTrimmedV3MskuAspectsV202110NoVariantSeedKnnRecallV1&_trksid=p2047675.c101195.m1851&amdata=cksum%3A301939904971bc3aa05c012f454cb1993e40c74cf4e1%7Cenc%3AAQAHAAABIMFr2e4EmAnM%252ByHZkULYKDIJ4L66fOjNL0iupgt%252BzO1%252F3AE1t3mNirUYB96NktMCicMagiS6mbeTl0xquGODv9mKDOxcEoI2WVBRqdRRH%252FcatUJgR62oSCG2I5PH%252F0k%252Bswml6ememZiAO6Jx18tmTWWkeEgWfgSKT1%252FDCbCTc9KDp69LokqoIgR0d2TiAtKSDzClWcpUABnRBHNfbcewgoi%252F3lO6rTTki2ntpsjI4dUTPNJGcVenYYWg6yzy2%252F7d7OJgINRX7rhJfJoqcpZjjQ4eEgasgINUCmmVX9AYS4KM%252BidhcdB%252FuIcA4izxr02A1%252FGSltCZfMq3mGW3TkGrqxQVkoY55f%252FO4y6sBU4owwceRj%252FbPo6B7b62vjsO%252BVOf2w%253D%253D%7Campid%3APL_CLK%7Cclp%3A2047675&epid=20035393154
Post by: mgb260 on December 11, 2022, 02:19:01 PM
Jim, First link, one rocker is straight and one offset. In the second link you don't want 3/8" stud you want 7/16". Pushrod oiling is recommended for roller rockers anyway.
Post by: mgb260 on December 11, 2022, 02:22:18 PM
https://www.ebay.com/itm/401935235057?hash=item5d9534f7f1:g:JdAAAOSwhfNds-0M&amdata=enc%3AAQAHAAAA8By8XWLkmC2t0s5Md5rTkSf1ZRgeHvbspbfPpGW%2Bd5YZezD%2Fvrzl5ksyY%2BC4lHn4B35inWQJqCGYdX4HWm1gDfGz8beJYRWtmhEXZJGRFTmzxAYtxRLGO3nGEA8PXTz5nLRSsBT9lE5FhKpNnUbdzJ5mzOxXvc%2Bi8rIKcLPhK49XaxuAUzjsKTRoRFb1bmtRtBPGnhG9oUP2sg7UAhlvbHBfLKuz2W%2FFeNL78dzOq%2B%2FsAPqC%2FePuFa%2FLlIqsJT%2FWISp%2FN48%2FXUKfBhxNqm19xKi6ioVaBG9fChZ1IIua%2Bxg7W7sg1Co%2FzEBLT4zv8uE7Zw%3D%3D%7Ctkp%3ABFBM9JGJqqBh
https://www.ebay.com/itm/363830579212?hash=item54b5fe100c:g:yhMAAOSwAoFhCViS&amdata=enc%3AAQAHAAAAsCOFFUEJitK443RXqpguKUNy1yMoi4VNy9sgimD4WD5PMNDuuVkiaUk22jBQN3K%2BNWtDCN2u0bkCSGbX%2BusEGaYq%2BmIiQzGzNO4QmI%2FFe%2F9W802Yg%2BYSWKmcOMWOWx9XQMmsE4PUnZgxvvrVJvjqUYEmnIHdpRfWahkLjp0EDhKMtVrRa7yFyHb2lGFbQkewyIGgT5uwPw%2ForMgMqqedly%2B9RT1CLdEdkCJXwOxnQYvc%7Ctkp%3ABk9SR7z9naqgYQ
https://www.ebay.com/itm/194380805618?hash=item2d41ffb5f2:g:F74AAOSwqIBhJ6E-&amdata=enc%3AAQAHAAAAsBCWUsgOsM8nQ1U4qRx8gQkrnK%2FDlv%2FBjvXK2YFhyEGLBZW0vtQRsq1ykhx13%2F3sHbpF%2Fm9sgJbQP3Ci%2FG3fsDm37vhBeZolRxs%2BE4HBycPXJ97PuazfTfQ7A4PxUG18gffIJy8CAHDt8EGiOd6FD7KkJPz4V8Oj%2Ft7pgLf1yzrxEuCOcWTuK8WLcXCTfGdKF8FZPDoU0u%2FDhD9rUWXwz%2FC861QmM6zR8LIGdClP6%2Fjx%7Ctkp%3ABk9SR8qh8tKgYQ
Post by: MGBV8 on December 12, 2022, 10:00:51 AM
Thirty years ago. I put a big solid lift cam in my 350.  Switched to 7/16" screw in rocker studs & Harlan Sharp roller rockers.  Figured with the 7/16" studs that I could forego the stud girdles.  Did fine.
Post by: BlownMGB-V8 on December 12, 2022, 11:26:09 AM
What exactly is the purpose of the guide plates? Can't be to center the pushrods in the holes. Is it to center the rollers over the valve tips?
Post by: mgb260 on December 12, 2022, 11:33:59 AM
Jim, Rocker alignment.
Post by: BlownMGB-V8 on December 12, 2022, 12:23:00 PM
OK if I go that route then I just need to find the stud set. Shouldn't be hard. Sounds like about $200 in rockers, studs and guide plates. Then bore out the procomp rockers to fit the shafts for the Rover heads. Cool. Means I don't have to machine up the new base plates for the rocker pairs.
Post by: mgb260 on December 12, 2022, 12:40:18 PM
Jim, studs are in link above. You need hardened pushrods with guide plates. .005 minimum pushrod clearance with the guide plate.
Post by: BlownMGB-V8 on December 12, 2022, 01:09:18 PM
I'll be ordering the pushrods from Smith Bros. I like that the stud type rockers are easy to adjust. I will wait until after assembling the parts to order the pushrods in order to get the height right.
Post by: BlownMGB-V8 on December 12, 2022, 03:19:56 PM
OK I placed the order. So SBC type individual roller rockers for the TA heads and modified Procomp rollers for the Rover heads bored to the rocker shaft size. Works for me and not terribly expensive. Having to resize the rockers would bump the price up of course if you had to hire it out but I don't know where you'd find rockers that size any cheaper.
Post by: turbodave on December 12, 2022, 04:08:48 PM
I have a set of the Volvo rockers as used on the SD1 Vitesse (twin throttle plenum) models.
Very interesting - they are apparently the Volvo B-series (based on every single person who heard it from someone else), but they look different from every B rocker I've ever come across.
The shaft is larger than the Rover shafts, and the posts are stainless steel.  Obviously the pushrods are also different.
They also have a small tack of weld on the adjusters, to make them "un-adjustable".
Post by: BlownMGB-V8 on December 21, 2022, 02:21:46 PM
OK, I have the plates, studs and rockers on one of the heads and had some pushrods that are really close but probably just a little long. It's a challenge to figure out what the ideal length would be since nothing is square to the deck. I have some adjustable pushrods but will have to turn then down where they go through the guide plates. I can figure this out but any hot tips here would help.
On the Rover heads though I've decided to bore or ream the Procomp rockers out to fit the Rover shafts. Some have suggested bushing them and if I had a correctly sized bushing at a reasonable cost I'd consider that but if the bushings cost $10 each that ends up being not far from the cost of a full set of the Procomp rockers so why bother with the extra labor? I think the aluminum will hold up OK.
Post by: BlownMGB-V8 on December 21, 2022, 04:19:54 PM
https://youtu.be/o5is9BsH5OU
Post by: mgb260 on December 21, 2022, 05:12:31 PM
Video explains it well. Have any pics. Did you fit a valve cover? Did you have to modify the guide plates? You do want oil through the pushrods so your lifters have to have the feed holes. Set screw to plug shaft oiling hole.
Post by: BlownMGB-V8 on December 22, 2022, 11:26:21 AM
By all rights you also have to look at the pushrod side in the same way. Draw your line and see if it is square to the pushrod at mid-lift. If it is, job done. If it is not you then need to decide which way to split the difference.
Post by: mgb260 on December 22, 2022, 11:41:36 AM
That video  is good for rocker geometry at mid lift.  I've always just made sure the line is the same level as the valve retainer. Never looked at the pushrod angle. Then check actual pushrod length with valve closed and lifter on base circle low point of cam.
Post by: MGBV8 on December 22, 2022, 11:52:06 AM
I don't see how that is possible.  The pushrod & valve stem are at intersecting angles.  When the rocker centerline is at 90 degrees to the valve stem, how can the pushrod also be at 90 degrees at the same time?
Post by: BlownMGB-V8 on December 22, 2022, 12:09:56 PM
The pushrod is at a different angle than the valve as you said, but the line for the roller tip is also at an angle to the line for the pushrod socket. So it is possible for both to be at right angles to the trunion. I don't know that it is, and there is some variance of course but it should be close? I'll be taking a look but it depends on engine and head geometry plus valve angles. Should be interesting to see how close it is. Seems like most inline engines have a  pretty vertical pushrod and both pushrods and valves being vertical isn't uncommon so it might be a mistake to switch rockers between the two. This could be where Max and I were having a bit of a communication breakdown during Happy Hour.
Post by: mgb260 on December 22, 2022, 01:10:50 PM
Guys, I've been thinking about it, and pushrod angle is irrelevant. That angle changes with the rockers movement. The main thing is at half lift the rocker is level with the retainer so the rocker is in the middle of the arc like the diagram I posted early in this thread. That way the wipe on the valve stem is minimized. With the shaft rockers you do the same thing by shimming or milling the rocker stands.
Post by: mgb260 on December 22, 2022, 01:51:08 PM
Also, initial rocker geometry and pushrod length are two separate things. Pushrod length is set after the rocker geometry when the cam is on the base circle low point and the valve is shut.
Post by: Roverbeam on December 22, 2022, 02:05:54 PM
If the rockers have geometry that is compatible with the head, within a couple degrees, then measuring the pushrod lengths after establishing the valve-to-rocker geometry will also give proper pushrod-to-rocker geometry.
Rover and Buick heads have about a 7 degree valve angle, and the pushrods lean inward/toward engine center, from the cylinder bore centerline by about a degree or two, for an included angle from valve-to-pushrod of about 6-9 degrees.
The rockers need an angle between the three pivot points that is similar to this, from the center of the pushrod's spherical tip, to the trunion center, to the valve tip roller's center.
Post by: BlownMGB-V8 on December 22, 2022, 02:50:00 PM
OK I think I got this. First shot below is on the lobe with the valve closed.
Next off the lobe
Next the rocker square to the valve
And a shot of the alignment jig I made.
So, after a bit of mucking about I realized that as long as the reference line remains square to the valve the stud threads can indeed be used as a measurement device so with .550' lift (.544" actual) the midpoint is 5-1/2 turns down from photo 3 which is off the lobe. Squaring up the data line and measuring the movement of the rocker required to meet the pushrod resulted in a measurement of .075" short on the pushrod from the midpoint. Pushrods come in .050" increments so that should be acceptable. Ideally I'd order longer pushrods but there is another consideration.
What was it Max said? His 1/3 to 1/2 figure? Was it that he liked that shifted to the long or the short side? IIRC his reasoning was that he wanted a gentler approach to initial opening?
Well no matter, what a slightly shorter pushrod does is pull down the pushrod end of the rocker, bringing that data line closer to being square with the pushrod. That's got to be better in terms of rocker arm geometry. I think it'll be fine.
What do you guys think?
Also on the TA heads the valve angle is 13 degrees.
Post by: Roverbeam on December 22, 2022, 04:36:29 PM
"on the lobe with valve closed"? Do you mean on the base circle?
The method in the video you posted does all the alignment with no pushrod, and with the valve closed.
Then, by counting turns, the whole rocker is translated downward 1/2 lift so that the alignment you did with the valve high is now the alignment at 1/2 lift.
Are your valves perpendicular to the valve cover surface? -is that what your alignment shims are resting on? Maybe it just the foreshortening of the pic? Is that sheet of aluminum pinched under the nose, on the valve stem?
Your rockers clearly have more angle than that between your pushrods and valves. I'm good at figuring out the geometries, but I don't have the experience to judge if that's within an acceptable range. Typical bellcrank theory has both pivot legs perpendicular to the direction of the inputs. The fact that valves are constrained to only sliding in/out, while the pushrods can articulate with the arc may have effects that I'm not aware of?
Just for reference, since it's on the shelf and easy to take a pic, here's the angle on a TA rocker for 215/300/340/Rover heads:
And while getting that pic, I measured the 300 head I have - they are 10 degree valves (I had pulled a dimension off a drawing earlier, rather than walk trough the snow to get to the real thing).
Post by: MGBV8 on December 22, 2022, 04:58:56 PM
He wanted the rocker 2/3 of the way down because of the stiffer spring pressure as the spring is compressed.  Less wear due to not fighting the spring as much.
I don't see how that reasoning jives with the mid-lift geometry at all.
Post by: BlownMGB-V8 on December 22, 2022, 05:57:45 PM
Well, it's a SBC rocker, apparently they had a 23 degree valve angle. so we're looking at a 6 degree difference. There might be a better choice for the TA heads but maybe not a cheaper one. One option might be to replace the cups with longer ones, maybe even an adjustable one. That would allow adjusting the rocker angle to match the pushrod-to-valve stem angle but might complicate things with the pushrod oiling.
The top photo was as described, look at the dimple in the pushrod.
The aluminum plate has a hole that allows it to sit on top of the retainer. I had to hold it in position while checking but maybe some sort of spring might fit between the plate and the rocker body to do that. I haven't tried it. A little tricky to hold in place while trying to take a photo, mainly because the small retainers don't have much of an area for the plate to sit on. But I think my results are pretty accurate.
I decided I would have to trim the guide plates for gasket clearance. In retrospect I think it would have been better to have just bought the TA guide plates. I still might do that.
If nobody sees a problem I think this is good enough.
Post by: mgb260 on December 22, 2022, 06:27:08 PM
You guys are really over thinking this. Look at my diagram on page 1. You just want the rocker level with the retainer at mid lift so it is in the middle of the arc. No pushrod yet. No spring. Just mark the valve on top of the guide. Mark it .275 above the first mark. I use a piece of tape to hold the retainer and keepers on. Lower the valve to the .275 mark. Tape to hold the valve at that position. Rocker should be in same plane as the retainer. Mid lift setting is done. Then you use an adjustable pushrod with valve closed and taped up, lifter on the base circle of the cam to figure pushrod length. Those rockers look nice!
Post by: mgb260 on December 23, 2022, 01:44:13 AM
Jim, Another rocker video:
https://www.youtube.com/watch?v=Sr4JbpO6034
Post by: BlownMGB-V8 on December 23, 2022, 11:12:51 AM
I've decided to resell these rockers on ebay and order the TA rockers and guide plates. The cost is $135 higher (plus I'll lose a bit on the resell) but the rocker angle should be correct (I will check), but the single most important consideration is that these rockers do not hit in the center of the valve tips. They are offest to the outside. Now this might not be a real problem with a standard setup but because I'm running titanium valves I'm installing lash caps and as a remnant of the old application the valve tips have a small groove around the tip which theoretically could allow the lash cap to cock a bit if the roller is far enough off center. I don't think it is that far off and it would probably work, but at high speed with that stuff all bouncing across hell's half acre who can say? So I'm going to do the safe thing. It's not a huge price to pay compared to the rest of the investment in this engine.
Now, with that problem solved, it's back to the original topic of this thread and the use of the Procomp rockers on the Rover heads. The shafts I have do have a little wear, about .0015" so I'll be breaking down the other rocker shafts I have on hand to see if there's anything better at hand. Then I can decide if new shafts are justified.
Next I will be checking the rocker arm angle to get some idea of how far it deviates from stock.
Then I'll look at setting up to bore the rockers. More on that later.
Post by: BlownMGB-V8 on December 23, 2022, 02:22:24 PM
It's possible to use the Procomp rockers if certain concessions are made.
The adjuster needs to be run out to about the limit of it's adjustability to match the rocker angle of the stock rocker.
It will be using a plain bore bearing with the rocker body as the bearing material.
And the biggest issue, the distance from the rocker shaft to the valve tip is a bit far. and puts the roller off center on the valve stem. Some of that can be corrected by moving the enlarged bore off center but it will still be past center. Maybe not enough to matter, I will probably go ahead and use them. But there may be better prospects out there.
For me, this is a refresh on a good engine. It will get new bearings and a different set of heads with the piston dish deepened to match, but it isn't a fresh build. If it was I think I'd be looking for some rockers that were a better match.
Post by: mgb260 on December 23, 2022, 02:40:47 PM
Jim, On the push rod cup you could use longer pushrods.
Post by: DiDueColpi on December 23, 2022, 02:44:53 PM
The rover rockers are offset Jim. Can you accommodate that with some machining to the procomps?
Also moving the shaft bore around is going to change your ratio. It might be better to move the pedestals.
Post by: BlownMGB-V8 on December 23, 2022, 04:18:37 PM
Yeah, I don't think moving the pedestals is going to work. You're right, the ratio total lift will take a hit, I'm not too worried about that. The procomps are also offset but not the same. I hope I can get them to line up good enough though.
On pushrod length, that adjuster position was the point at which the pushrod angle was about the same, so a length measurement with it in that position should give the closest geometry to the stock rocker. In that location the adjuster does move a little below the trunion centerline so it also has a very slight negative affect on the ratio. But again I think I can live with that. I am not that married to the current lift figures.
Post by: gsjohnny on March 17, 2023, 09:48:29 PM
been a long time for me.
don't know how much difference between 350 and other sbb rockers.
but i run 1.65 rollers. with the 350 casting for lack of room, i didn't want a bigger cam, i wanted more rocker ratio.
i bought some stud roller1.6 and 1.7 sb fords. i took one apart and reamed the hole to 350 size, only issue
with the ford vs sbb is shaft c/line to valve roller. the fords are about .050 longer. i could move the hole over,
but the 1.7 ratio would diminish. don't know how much. but its all doable.
i bought some 1.7 shaft rollers. this would require a new shaft with different o.d. spacers. still working on how to make it work.
one other idea, which i have lots of 350 heads, is to adapt ford 390-428 shaft rockers and stands. i can machine the stands
to whatever dimension that will work with the fords. looked at them, just have to buy them.
btw, those who try other parts to work, how much junk have you made and keep? i know i have a bunch of scrap. lol
Post by: mgb260 on March 17, 2023, 09:57:23 PM
Johny, Welcome aboard!
Post by: gsjohnny on March 18, 2023, 12:36:42 PM
being a scatter brain doesn't help. look for something, i end going all over the world. lol
the 350 whines for me. i may have to expand my r&d to the little engines. got 3 340's, have to find a 300.
Post by: BlownMGB-V8 on March 18, 2023, 03:18:44 PM
Only really two reasons to use a 300 over a 340. One is if you don't have room for the 340 (the MGB falls into this category) Two is if you want a better intake than the stock factory cast iron 340 4bbl intake and aren't willing to either use spacers on a 300 intake or to fabricate one. Other than that I don't really see an advantage and with the larger mains the 340 crank should be a little stronger. There is only 2lbs difference in the weight of the blocks. I modded an MGB to accept the 340 and fitting the 455 turned out to be almost exactly the same except for the exhaust. By contrast the (RB) MGB needs no body mods to fit the 300, making it the logical choice.
Post by: MGBV8 on March 18, 2023, 04:26:49 PM
#3  If you want a smaller displacement V8.  ;)
Post by: BlownMGB-V8 on March 18, 2023, 05:16:39 PM
So true.
