Hi,
I have a number parts I'm looking to sell. Just got into this project about 5-6 years ago, and now really just dont have time to make any progress.
I have a collection of buick v8 215 parts. There is a complete engine that doesnt turn (or at least I havent tried over the last 3 years. I bought it, put some ATF in the cylinders to see if it would free up, but havent ever tried real hard to turn it over).
I also have a cleaned block that will likely need the cylinders honed.
There are a number of engine parts all out of the cleaned block. There are really only 6 decent pistons in the bunch.
The cylinder heads are rough, but could probably be cleaned up and rebuilt, however 1 does have a broken valve.
I have an original clutch and a newer clutch for the engine.
A McLeod hydraulic throwout bearing. This will likely need to be sent back to McLeod to be rebuilt.
Additionally I have a T5 Transmission (I believe out of Camaro). This appears to be in good working order.
I have a driveshaft to go from the T5 to a stock MGB rear end.
The supercharger is off a buick 3800. Appears to be in good working order.
I would like to get the following:
Engines (both and all the parts minus the bellhousing, supercharger, driveshaft, trans, new clutch): $500
Transmission, Bellhousing, driveshaft, new clutch, throwout bearing: $750
Supercharger: $125
Or come take everything for $1,200
I also have a 1973 MGB, that I will likely part out as there is just too much rust on it (floors, sills, and enough other bits), if you're interested (original 1800 engine and trans are already gone). I paid $750 for the car, but that was probably too much...
Located Just outside Madison Wisconsin.
Dave
More Pictures
Pictures of the car
I'd be interested in just the bellhousing, shipped to zip code 20180.
I am interested in everything except the car. I have a MGB body but want to do another v8 conversion.
I'm interested in the driveshaft.
Is the bellhousing still available? if so how much for just that?
