General Category => Engine, Transmission, & Rear Axle assy. => Topic started by: e.drooy on August 19, 2021, 03:04:24 AM
Title: How much do lifters expand when engine running? Yella Terra rockers hitting the covers
Post by: e.drooy on August 19, 2021, 03:04:24 AM
Hi All :)
My name is Erik and Im in the process of building/modifying my MGB V8. And Ive run into a little problem with my new Yella Terra rockers...., the covers dont fit anymore. So the plan is to make a layer between the covers and cylinder head to lift the cover clear of the rockers. The question is how much should i raise the covers to stay clear of the rockers when the engine is running?
Thanks so much for help! Will soon post pictures of the project
Title: Re: How much do lifters expand when engine running? Yella Terra rockers hitting the covers
Post by: mgb260 on August 19, 2021, 10:54:12 AM
There are valve cover spacers you can buy on Ebay for that purpose.
https://www.ebay.com/sch/i.html?_from=R40&_trksid=p2499334.m570.l1313&_nkw=rover+v8+valve+cover+spacers&_sacat=6000
Post by: roverman on August 19, 2021, 07:11:00 PM
OR you can go with 340 Buick = more rocker room and they look different.    Art.
Post by: e.drooy on August 25, 2021, 06:00:34 PM
hmm, the idea is to go for 3D printing, the same as for some other parts... no need to lift the covers more than strictly necessary because the thor manifold is in the way of raising the covers.
Post by: RoverP6B on December 15, 2021, 09:47:21 AM
You can also use Offenhausers valve covers as these are a bit taller than stock, I'm also using Yella Terras. Graham
Post by: Robrover on January 08, 2022, 09:22:57 PM
I fitted a custom metal spacer between my 4.6 block and P6B covers to clear the YT roller rockers. You may also be able to glue two cork rocker cover gaskets together to achieve enough clearance, though the spacer or a taller other make cover is a better option.
Post by: rficalora on January 15, 2022, 09:47:11 AM
Hydraulic lifters have a total travel of about 0.200.  So, start by measuring the gap between the cover and cylinder head, subtract the gasket thickness, and add 0.200.  That plus a few thousands clearance would be the absolute minimum.  But, personally, I would want at least 1/4" or more clearance.  That way I wouldn't have to worry about differences in gasket thicknesses that might get used over the years.
Also, if your covers aren't baffled, when the rockers are that close, you'll need to consider how to keep oil from getting sucked into your PCV &/or quickly saturating the breather.
For reference, this is a picture of my cover which has about 1/4" clearance to the under side of the cover.  They are not baffled.
If you can 3D print, why not just print yourself a few sets of washers at
