General Category => Engine, Transmission, & Rear Axle assy. => Topic started by: donfaber on July 27, 2021, 12:13:08 PM
Title: Crankcase ventilation Rover 3.9L V8 w/ Edelbrock carb
Post by: donfaber on July 27, 2021, 12:13:08 PM
In a nutshell (I'm 66 and still learning) - for my rover V8 with Edelbrock carb.... PVC valve from one valve cover to base of Carb, vent line from other valve cover to air filter inlet on carb.
Title: Re: Crankcase ventilation Rover 3.9L V8 w/ Edelbrock carb
Post by: donfaber on July 27, 2021, 09:44:12 PM
Is the setup I've described "correct?"
Post by: DiDueColpi on July 27, 2021, 10:00:36 PM
Absolutely Don. It's the classic way to ventilate the engine. And it will work just fine. You will have to play around with PCV sizes to fine tune it, mostly to stabilize the idle.
The more modern set up is to use a constant depression regulator to provide a regulated pressure drop inside the engine. This is a little more complex to achieve but it virtually eliminates oil leaks. That's the downside as you no longer know if your British car has oil in it.
Live like you mean it.
Post by: donfaber on July 28, 2021, 09:18:57 AM
 -- moved topic --
Post by: donfaber on July 28, 2021, 10:08:37 AM
Thanks, Fred!
Post by: BlownMGB-V8 on July 28, 2021, 02:52:39 PM
Use the largest practical hose you can for the vent line. 3/4 is good and 1" isn't too big. 5/8" would be OK if these engines didn't have a reputation for blowby. Be sure there is a flame trap in that line.
Post by: MGBV8 on July 29, 2021, 09:29:12 AM
"The more modern set up is to use a constant depression regulator to provide a regulated pressure drop inside the engine. This is a little more complex to achieve but it virtually eliminates oil leaks. "
Would love to hear more about this, Fred.  As Jim mentioned, these engines tend to be heavy breathers.
Post by: donfaber on July 29, 2021, 12:45:17 PM
Jim - I assume that's not the same as a breather - can you recommend a flame trap or supplier? Thanks
Post by: DiDueColpi on July 29, 2021, 01:13:33 PM
Virtually all newer vehicles use some form of this breather system Carl.
It's essentially a large pressure regulator connected between the crankcase and the intake plenum.
It maintains a constant pressure drop differential in the crankcase of around 2 psi. No other vents or breathers are used.
It works very well. We see engines with several hundred thousand miles on them that are perfectly dry.
A good example is the Jag/Rover part AJ87773 to give you an idea.
Post by: ex-tyke on July 30, 2021, 08:06:16 AM
Here ya go, Carl!
Post by: MGBV8 on July 30, 2021, 09:23:42 AM
I need one!
Post by: donfaber on July 30, 2021, 10:20:48 AM
Let me know where u find it, Carl!
Post by: BlownMGB-V8 on July 30, 2021, 10:22:25 AM
Is that any different from the big metal one used on the TR4? So no fresh air inlet with those huh?
Post by: ex-tyke on July 30, 2021, 11:59:40 AM
Seems to be used on 2000 - 2009 vintage Jags.
Could spend $50+ for a new one, try the wrecking yards or steal one off Kelly's XK8  .
Post by: DiDueColpi on July 30, 2021, 01:35:00 PM
Nope no fresh air Jim just a light vacuum. The Oringed part goes to the valve cover and the barbed fitting goes straight into the intake manifold plenum. A silicone diaphram and spring regulate the pressure in the crankcase.
Try undoing the oil filler cap while the engine is running Graham. You'll see what I'm talking about.
Post by: BlownMGB-V8 on July 31, 2021, 09:36:52 AM
So... is that any different from the big metal one used on the 1966 TR4?
Post by: MGBV8 on July 31, 2021, 09:42:05 AM
Sounds like an oversize PCV.
Post by: donfaber on July 31, 2021, 02:51:26 PM
Found #379-580 - for 70-71 TR6 - Moss Motors
Post by: ex-tyke on July 31, 2021, 03:36:15 PM
A GM version of the crankcase regulator valve # 25097699
Post by: MGBV8 on August 01, 2021, 10:06:50 AM
"Found #379-580 - for 70-71 TR6 - Moss Motors"
Moss says that is a just flame trap, Don.
Post by: BlownMGB-V8 on August 01, 2021, 11:25:32 AM
https://rimmerbros.com/Item--i-GRID200273
Post by: donfaber on August 01, 2021, 12:49:32 PM
Carl - I'm only installing a flame trap on left side - pcv already installed on right side. Seems to be the consensus?
Don
Post by: MGBV8 on August 02, 2021, 09:13:34 AM
Right.  I got hung up on Fred's suggestion  of a crankcase depression regulator & forgot that you were only looking for a flame trap.  :)
I am intrigued by this CDR.  Not sure I really understand the difference between it & a PCV.  I have read that a CDR is a essentially a PCV for diesel engines. It functions in the opposite manner in regards to vacuum.
Post by: BlownMGB-V8 on August 02, 2021, 10:45:15 AM
Part of a stainless steel pot scrubber pad makes a pretty good flame trap. You can use it in any suitable enclosure. As an example, I have about half of a pad strung out and drawn into 1" diameter length of silicon hose which runs from my  mechanical fuel pump block off plate up to the inlet of my Enderlie style intake scoop. You can probably see it in my avatar, the hose is blue which contrasts with literally everything else on the car. Rover uses a canister on the valve cover similarly filled.
I'd like to see an explanation of that regulator compared to the TR4 pcv. Is there a difference in the way they work?
Post by: ex-tyke on August 03, 2021, 08:25:20 AM
QuoteI'd like to see an explanation of that regulator compared to the TR4 pcv
Looks similar to the PCV that was used in ''65 - '67 MGB's , Spitfires and who knows what else  - I know my '64 never had one.
(photo courtesy of Moss)
Post by: BlownMGB-V8 on August 03, 2021, 09:55:19 AM
It also has one inlet and one outlet.
Post by: DiDueColpi on August 03, 2021, 09:56:17 PM
The "TR4" pcv is essentially the same as the cdr system.
It's biggest flaw was that it was prone to ingesting oil due to the limited drain back from the cylinder head. (try filling the TR engine with oil. The valve cover fills almost immediately)
It also doesn't have big enough plumbing, probably due to the drain back issue.
The rear crank scroll seal was also a miserable thing that allowed air (and contaminants) to enter the engine, defeating the pressure drop and exacerbating the drain problems with the upper engine.
It's biggest problem however, was that it was different.
 Most didn't understand how it was supposed to work and hobbled it with catch cans, road draft tubes, crankcase vents, etc. They then removed the valve because the engine wouldn't idle properly.
It gained an undeserved reputation as  a bad design.
That problem seems to continue to this day. With almost any engine or unconventional system falling into disfavor.
 Many "fixes" for engine breathing issues still recommend catch cans and open breathing mods.
 None of that is required with a properly designed and operating system.
Post by: Gswest236 on October 19, 2021, 10:09:58 PM
I had this exact issue with my GT V8. Oil pumping out every possible seal. After I got the CDR installed, no oil on the floor after a spirited drive.  And no oil on the Offy valve covers around the oil fill openings.  Best $50 I've spent yet  (CDR part exactly as shown in this forum above). Look on ebay or Amazon etc.
Post by: dherr2 on February 01, 2023, 06:34:48 PM
I am working on a Rover 3.9 that is having a similar issue with oil leaks. I plan on fitting the CDR, will have it on Friday. My understanding is this provides a controlled constant negative pressure in the crankcase so oil is not being forced out under pressure.
So If I understand this correctly, I need to connect the o-ringed side to both rocker cover ports and the other side goes to manifold vacuum correct? Do I use the pvc vacuum port on the carb or do I need to use the port (currently blocked) under the carb on the manifold?
I have the old style Rover valve covers, so just an oil cap, and one vent tube on each cover.
Previously was running a standard PVC from one cover to the carb and a filter on the other cover, but still seeing pressure causing the oil leaks.  Looking for how best to run the lines to the new CDR to eliminate the problem for good. Appreciate the help.
Post by: 88v8 on February 04, 2023, 10:33:31 AM
The crankcase needs an air inlet otherwise it can't be scavenged. So that's whichever rocker box you currently have as the inlet, which may have a little filter on or not.
What you're scavenging is the crankcase, and both rocker boxes are connected to the crankcase so only one of them needs to be connected to the o'ringed side..
For the CDR, I would use the connection point to the manifold rather than the PCV port.
My own RV8 is vented from the original flame trap to the underside of the air filter, no PCV.  Mind you,  it's not parked over a clean surface so I couldn't tell you whether there are any leaks, but the inside of the rocker boxes is nice and clean.
Post by: BlownMGB-V8 on February 04, 2023, 01:09:52 PM
With oil leaks the problem is not pcv but blowby. Blowby is the thing that creates positive crankcase pressure and it will always exceed the capacity of any pcv system under full throttle. The more power the engine produces, the more blowby it makes. So the answer is a means of routing the blowby to the intake.
Ever wonder why drag race engines used as many as 4 breathers on the valve covers? To vent the blowby, they certainly weren't for looks. If they weren't needed they wouldn't be there. That should give you a small hint of what you are dealing with. And the more worn the engine is, the more the blowby.
Here's a tip. You use a block-off plate for the mechanical fuel pump right? So drill and tap that plate for the largest pipe thread you can, install an elbow to point it up, and run a big hose to the air intake. Stuff the hose with a scrubber pad for a flame arrester and then plumb the pcv system however you like, making sure there is some sort of a restriction there. A pcv valve is a good idea because it allows full flow at low pressure conditions (WOT) to supplement the blowby tube.
Post by: dherr2 on February 05, 2023, 10:07:37 AM
Thanks Jim, I will definitely try this venting solution from the fuel pump blank off plate. Question for you, do you suggest running this to the air filter inlet? Then a standard PVC system and breather on the valve covers? So basically the PVC system works as intended but blow by pressure is vented to the intake as needed?
Post by: BlownMGB-V8 on February 06, 2023, 12:34:50 PM
That is correct Dave. The only difference between this and a factory setup is that the factory connected the breather line to the opposite valve cover. Aside from increasing the line size.
