I have a couple sets of aluminum 300 heads, cleaned and bead blasted but should be gone through. Look to be in pretty good shape. $300/set.
1 300 crank, I'll have to look at the journal sizes, they may be stock and looked pretty good. $275
An assortment of 300 bellhousings, 4 of them I think. $100-200 depending. All cleaned and blasted. Send me a PM.
Buyer pays shipping of course.
One set of heads gone.
I have 2 bellhousings left, both have been baked and bead blasted. One is a double hump cable linkage type with no clutch fork or cover but does have the outside adjustable pivot ball $150, the other is a single hump mechanical linkage type with the clutch fork $175. I have a pending inquiry on the last set of heads, and I think I will keep the crank for a little while until I have completed the rotating assemblies on the two engines I'm now building.
Jim,thanks for sending pictures but I" worried about some of the pitting on surface of heads. I might try talking to a machinest about that, so don't hold them because of me.
thanks Bill
The heads are gone and I'm holding onto the crank for awhile, until I get the bottom end of the stroker 300/350 built so that leaves the bellhousings still available.
