General Category => Classified Ads: Swap Parts Here! => Topic started by: Zack_008 on June 29, 2019, 03:30:26 PM
Title: SOLD! --- Buick 300 aluminum heads and intake
Post by: Zack_008 on June 29, 2019, 03:30:26 PM
Buick 300 aluminum heads. Look to be mismatched. Casting numbers are CFD1358219 12PM and the other 19PM. One head would need some attention around 2 of the exhaust ports from corrosion. Both should be worked around the dog bone water jackets. Nothing crazy, just typical old aluminum Buick heads. Intake has both water neck bolts broke and one breather bolt broke in it.
Looking for 600+ ride for the set.
I have other 215 stuff, heads blocks, timing covers, cranks, looking for something? Ask me.
Zack
Located in 97233
Title: Re: Buick 300 aluminum heads and intake
Post by: BlownMGB-V8 on June 30, 2019, 06:31:10 PM
That's a deal. Somebody ought to jump on that.
Post by: Zack_008 on July 21, 2019, 10:27:37 PM
Willing to split if someone just wants the heads. I know the deck height from the rover/215 is different from the 300 so it is application specific.
Post by: MGBV8 on July 22, 2019, 08:48:56 AM
The intake is 300 specific, Zack.   The 300 heads can/will/have been used on  Buick 215 & Rover V8s.
Post by: BlownMGB-V8 on July 22, 2019, 10:56:01 AM
I've seen those intakes go for as much as $400 and the same for a set of heads. I know for many of us it seems like a lot but it's the only 4bbl intake you can get for that motor. You can find them for less sometimes but the last one I bought had to have a heliarc repair. So I think the price is pretty fair and then there's the scarcity. Not available quite as often as they used to be. Thinking about it? Coudn't hurt to make an offer.
Post by: MGBV8 on July 22, 2019, 09:40:58 PM
" it's the only 4bbl intake you can get for that motor."
Only aluminum one. The only other year for 4 bbl was 1965 & it was cast iron.
Post by: Fozwanger on July 27, 2019, 08:31:35 AM
Hi,
Are the heads available and would you ship to Uk?
Jeff
Post by: Zack_008 on July 29, 2019, 08:33:49 PM
PM sent
Post by: Zack_008 on September 25, 2019, 10:58:00 PM
I just picked up a 300 so I'm keeping the intake.
Heads are still available. $350 + ride for the heads.
Post by: Zack_008 on September 27, 2019, 09:00:34 PM
***SOLD!!!***
Thanks.
