General Category => MG Sports Cars => Topic started by: danielruhe on May 29, 2019, 03:44:23 AM
Title: Mob steering column swap
Post by: danielruhe on May 29, 2019, 03:44:23 AM
Im looking to buy a later model steering column for my 1974 mgb 302 swap project.  Is there any differences between the 1975-1980 mgb steering columns? Also, do the electrical components and steering lock/ignition directly transfer to the later model columns? And lastly, other than the firewall modifications is there anything else needed to bolt the column directly in place?
Title: Re: Mob steering column swap
Post by: 302GT on June 28, 2019, 08:08:15 AM
All columns have the same dimensions at the rack end: 3/4 inch, 48 splines. They differ at the steering wheel end. 70-76 are all the same. 77-80 is different. The  shaft where the steering wheel connects to can be interchanged between the two types of columns. The later columns did not have a central horn button, the horn was operated by the turn signal switch. However, parts are interchangeable. Still, it is easier to try to obtain a 741/2 through 76 column for your needs so as to avoid modifications..
