General Category => Engine, Transmission, & Rear Axle assy. => Topic started by: roverman on February 12, 2019, 12:26:25 PM
Title: A 215 x Two ?
Post by: roverman on February 12, 2019, 12:26:25 PM
Where to look for any builds of 215/RV8 as a V16 ?  I may inherit an unfinished project.
        Thanks, art.
Title: Re: A 215 x Two ?
Post by: hoffbug on February 12, 2019, 01:52:07 PM
A friend's uncle had two mounted on a pulling tractor. His brother still has the blower manifolds and a bunch of the pieces
Post by: roverman on February 12, 2019, 05:22:08 PM
Thanks Tony, any pic's ?  These will be joined/welded at the ends, with 9 mains, which  shortens the package about 4-5" ?
Post by: hoffbug on February 12, 2019, 06:35:07 PM
Post by: hoffbug on February 12, 2019, 06:35:58 PM
Post by: hoffbug on February 12, 2019, 06:37:14 PM
Those two where his uncles..He doesn't know too much about how it was set up... The next two are another tractor.
Post by: hoffbug on February 12, 2019, 06:37:47 PM
Post by: hoffbug on February 12, 2019, 06:38:20 PM
Post by: roverman on February 12, 2019, 06:45:57 PM
The bees knees  or a lightweight freight train.  Thanks, Art
Post by: MGBV8 on February 12, 2019, 10:16:11 PM
Like this ('cepting this is  Chevy LS V12 vs Buick V16).
https://www.lsxmag.com/news/the-ls12-the-inside-scoop-on-the-v12-ls-engine/
Post by: WandaColebo on March 01, 2022, 01:41:52 PM
@hoffbug it would be fun to see what would happen if you put all this on modern tractors. Would it make a race car? LOL. My uncle had parts like this, very old but well preserved. He sold them on eBay for good money and bought himself a great tractor from these guys https://www.machinerydealer.co.uk/compact-tractors-for-sale/. And now enjoys life on his farm. Sometimes he tells me he regrets selling his Chevy LS V12, but still, there was nothing to do. A farm needs a working tractor, not old junk. Peace to all.
Post by: roverman on March 02, 2022, 04:44:49 PM
All I need to do is semi-retire.... My build is to be (2) 4L RV8's, stress mounted,( common main girdle and rocker covers).
   Splined snout of rear engine engages splines of front engine. Everything aluminum except streched T-bucket body.
        Cheers,  Art.
Title: Re: 4L. RV8 x Two and so it begins
Post by: roverman on January 25, 2023, 02:56:08 PM
Finally getting to it. Initially 450-500 hp. ? Complete V16 should be about 550 lbs. Projected car weight of 1,600 lbs. +/-. Not sure on dry sump pump ratio to crank speed. 100% or 50% is easiest.
        Onward,   Art.
Post by: DiDueColpi on January 26, 2023, 01:39:37 PM
What about Mickey Thompson style?
Two engines side by side. One canted left the other right.
They were joined by a gear drive if I remember right. Not too much wider than a regular V8.
.....Just looked it up. The car was called the monster and used 2 pontiac engines.
He did another chain driven show car earlier.
Post by: roverman on January 26, 2023, 02:04:10 PM
Donny Johansen and family drag raced "Twin Bears", 2 sbc's in "W" canted about 22 deg. This was just enough for exhaust.
  Drive output for each was flywheel teeth. LA Roadster Show had a "W" roadster.  I'm looking for low CG and smooth. At  a reliable 1,600 lbs, I'll need some skilled design.
                                                            Art.
Post by: BlownMGB-V8 on January 27, 2023, 11:49:29 AM
You will be pulling something off if you hit that weight.
Title: Two RV8's all in a row ?
Post by: roverman on January 30, 2023, 02:56:43 PM
Yes indeed, which is why I'm building. Silly as it sounds, frame is .125" wall x 2" x 4" alum. tube. Unthinkable except entire
   powertrain is, stress mounted. Finally get to test if I learned enough at Chaffey College : "Engine and Race Car Design".
        Onward,  Art.
Post by: ag1234 on April 04, 2023, 11:13:11 AM
Update, made the mill cutter for 1.375" dia.x 10 splines. Broach for female splines is from Lenco racing trans,{same dia.}
        Onward, Art.
