General Category => Engine, Transmission, & Rear Axle assy. => Topic started by: Young olds on August 30, 2018, 01:13:53 PM
Title: I need help deciding what to build.
Post by: Young olds on August 30, 2018, 01:13:53 PM
With my current engine in the Opel being bad I've been trying to decide what to build as a replacement. I have a buick 215, .030 over, clean block probably would be fine with just a fresh hone and new rings. Seems like my cheapest and easiest option but the pistons are dished and would result in low compression. I also have a 4.2 with a pitted cylinder wall, probably needs at least .020 over to clean up. What I really wanted to do was use the 4.2 block with my stroker crank(3.315") and 305 pistons to build a 290 but I don't want to get into custom length rods or pistons. I'm not hung up on getting the most cubic inches I just want a strong runner that uses off the shelve parts.
Title: Re: I need help deciding what to build.
Post by: Young olds on August 30, 2018, 09:57:29 PM
Btw this is going to be for my road race/autocross opel.
Post by: Young olds on September 03, 2018, 11:28:44 PM
Does the ati damper work with a wet sump system? In the notes it says for dry sumo systems but it's the only aftermarket damper I can find
Post by: MGB SS on September 12, 2018, 09:04:41 PM
Get different pistons for the 215 going to be apart to re-ring anyway, just a thought
Post by: BlownMGB-V8 on September 13, 2018, 02:50:12 PM
I think if a damper is made to work with a dry sump it should work equally well with a wet sump. Can't imagine any reason why it wouldn't. But to be safe, have the rotating assembly balanced.
Post by: Young olds on September 14, 2018, 12:41:06 PM
That's what I was thinking but wasn't confident
Post by: BlownMGB-V8 on September 14, 2018, 01:52:46 PM
Also check with "Damper Dudes" for rebuilt units.
Post by: Young olds on September 24, 2018, 12:02:25 AM
I believe I found and fixed my issue with getting water in the current engine, if it works out I won't be building a new one for a while.
