General Category => Bodywork, Paint, Interior, Trim, & Wiring => Topic started by: NAS1966 on August 01, 2018, 11:44:26 AM
Title: Fender flares
Post by: NAS1966 on August 01, 2018, 11:44:26 AM
Hi y'all
would I need front and rear flares from Dodge Omni or just the rear from my 73 MGB?
Title: Re: Fender flares
Post by: MGBV8 on August 01, 2018, 02:29:50 PM
The Omni flared fender cars that I am familiar with, only used the front flares from the Omni/Horizon swapped to the opposite side of the car.
Post by: rficalora on August 01, 2018, 02:33:33 PM
You can use either... but, the fronts are a lot less work.  The rears have an inner fender/wheel well attached at the lip.  To use them on the MG, you'd need to cut that away & trim it away for a neat look & no rough edges.  10 years ago, that probably wasn't worth the effort.  Now that Omni's are a lot harder to find, it might be worth doing as one Omni while hard to find, will still be way easier to find than 2.
That said, VW rabbit flares are very similar & fenders are available new very reasonably.
Post by: NAS1966 on August 02, 2018, 09:41:56 AM
Thank you for your replies - the inquiry was due to an ebay listing I found fo OMNI fender flares - check it out
New Universal Car Fender Flares 4 Piece Flexible Durable Polyurethane Body Kits
https://www.ebay.com/itm/New-Universal-Car-Fender-Flares-4-Piece-Flexible-Durable-Polyurethane-Body-Kits/292560531132?fits=Model%3AOmni&epid=15004644644&hash=item441df76ebc%3Ag%3A7AIAAOSwugha9qBt&_sacat=0&_nkw=Omni+fender+flares&_from=R40&rt=nc&_trksid=m570.l1313
What do you think?
Post by: rficalora on August 02, 2018, 03:36:03 PM
Not the same thing.  Those are Polyurethane (plastic) bolt on flares.  Dodge Omni flares are metal & part of the fender.
Post by: NAS1966 on August 03, 2018, 09:19:52 PM
Thank you for your feed back - so,  Rob mentioned using VW rabbit fenders?  Would I need only front ones? Has anyone done those on the "How its Done"  section?
Post by: rficalora on August 03, 2018, 09:31:03 PM
There's a ton of info on Rabbit flares on this board.  Just put "Rabbit flares" in the search box in the upper right of the page and you'll get at least a dozen threads.  And yes, easiest would be to use all front fender flares - I've only seen new front fenders for sale.  Haven't seen any rear quarters discussed.
Post by: NAS1966 on August 09, 2018, 04:45:03 PM
I have looked and tried to find  Rabbit fenders I can use - no luck  Omni forget that - so I'll try to make my own using new shett metal and bending it to suit.
Thanks for all the tips.
Post by: rficalora on August 09, 2018, 05:07:22 PM
There are at least two on eBay currently.  But, if you have the ability to form your own, go for it.  Way less expensive that way and you can make any size you want.
Post by: MGB SS on August 09, 2018, 10:00:14 PM
Google 75 to 80 vw rabbit fender you will get more than you can count!   Kinda a Rabbit thing ;)
Post by: mgb260 on August 10, 2018, 10:16:30 AM
From this site:
http://forum.britishv8.org/read.php?2,20254
Post by: mgb260 on August 10, 2018, 11:48:41 AM
Here's another thread:
https://www.mgexp.com/phorum/read.php?40,2700867
Post by: BlownMGB-V8 on August 10, 2018, 03:51:09 PM
I'm a firm believer in the "roll yer own" method, particularly the rear fenders. Done two sets of them now. If you were close enough I'd let you use my English wheel.
Post by: MGB567 on September 29, 2018, 02:02:49 AM
If I new how I'd link my topic VW flares from MGE swaps. Pages of info
Post by: MGBV8 on September 29, 2018, 08:40:28 AM
Here ya go, Barrie.
https://www.mgexp.com/phorum/read.php?40,2949854
Post by: NAS1966 on September 29, 2018, 08:41:47 AM
 -- moved topic --
Post by: JEMRestorations on December 01, 2018, 07:03:40 PM
If it ain't Steel, it ain't real....
Post by: BlownMGB-V8 on December 01, 2018, 08:57:13 PM
I like your attitude.
