It was pointed out to me that there are no comments in the build section. So here's your chance should you have questions or comments.
http://forum.britishv8.org/read.php?13,62704
http://forum.turboford.org/ubb/ultimatebb.php?ubb=get_topic;f=30;t=000031
Welcome Dennis, great looking car, join us in Dayton!
Well it has taken a few nights to get through your build blog at Turboford but was well worth the time, Great build and great record of the progress. Years ago I had a turbo T-bird (1985), great choice for your B swap
And yes welcome to the group
Thanks.
I had previously thought I would be adding more power with additional engine modifications. But it is so much fun to drive the way it is I may put that off for a while.
The car is traction limited through the first 3 gears.
Yes without a lot of remodeling its hard to use much more than 250-300 hp with a 2200# MGB I was always planning on more HP in mine but until the traction issue is addressed What is the point.
The part about your car is that it was as much work to put another 4 banger in the B as it was to put my V-8 Not saying you made the wrong choice because I think your car is great just seemed like putting another 4 in would be less work and re-design of the car but reading your build it certainly wasn't.
Joe
I was originally targeting 400 horsepower, and to do that I would need a different cylinder head and turbo. With that you also get good street manners. If I wanted to top that I think an aluminum LS would be the reasonable choice.
I think many of the modifications are related to power output - transmission tunnel, rear axle and suspension, radiator and then my choice of EFI - fuel tank, filter, fuel lines. Without all that stuff the swap is a piece of cake, but probably not very interesting.
