Does anyone know where I might source front turn signal lights such as these?
Those look full custom but possible early mustang fogs might do?
The bumper even has a mustang flair.
I agree with Fred, the turn signals look fully custom. Hard to tell because the pic gets grainy when I blow it up to see, but they look to be set back where the lens would be behind a chrome finisher.
I like the concept, although I'd probably lose the hood scoop and thin down the front bumper.
Interesting concept...but those wipers are never going to work!
I think the design, as a whole, is pretty angular. I do like the signal lamp concept. I toyed with the idea of late 60s GTO lamps but when I held one up to the grill they're so huge looking in comparison to the features of the MGB.
It's a good idea to think carefully before making changes to the body that alter or remove the traditional MGB styling cues. At one time we would do that to create something different but now, 38 years after the last MGB was made, they already are different. Enough so that they are becoming sort of exotic. Nobody knows what they are anymore. So the uniqueness is already there and the need to personalize is largely gone.
Changes for practical or performance reasons can usually be done while retaining those cues that identify the car, and this makes it much more likely the car will be properly identified rather than referred to as a kit car or a Porsche. I've experienced both even though all or most styling cues were still in place, but major alterations make it much more likely.
"Changes for practical or performance reasons can usually be done while retaining those cues that identify the car,"
Totally agree. Nobody under 30 knows what an MGB is so at least let the silver backs have a chance to recognize the car.
Not sure I'm following you guys. I still clearly see MGB. Anyone who didn't recognize it as a B wouldn't know the difference between it and an unmodified one. And anyone who did would clearly recobnize it's roots. What am I missing?
Well, that's an artist's rendition. To duplicate it you'd have to change virtually everything about the car so it probably would not be done. Almost all of the contours are off in subtle ways, and the front end treatment has very little in common with any MGB, same for the hood lines. All I'm saying is that the further you take it the less it will be recognized. Which is fine if that is the builder's intention, but having driven one of those for a few years I can tell you that it gets old having to explain that it isn't a Porsche.
Being RHD, they will do. They do need to be closer together.
Must be that whale tail. ;)
Like the others have said, this is a rendering, a drawing, not an actual car.
From the zolland design web site:
"We also do visualisations of products and houses/buildings in a photorealistic manner."
Here is another version of the B.
No Carl, actually it was the MK-I tilt hood design that did it for me. After that I went back to traditional MGB styling. (Though there was one interrim fiberglass design, the Mk-II that was based on the T series. That on didn't last long.)
"It's a good idea to think carefully before making changes to the body that alter or remove the traditional MGB styling cues."
Gosh Jim, you of all people I thought would embrace this, and maybe Stabe? so here's another idea to chew on.
Speedway could have something that appeals to your taste or check motorcycle aftermarket catalog (j&p) or eBay. Harley softail heritage turn signals would be about the right size for this grill modification
Tim, I do approve of mods that aesthetically improve the looks of the car, but I don't think mods that take it farther from recognition as an MGB are a particularly great idea. So for instance when an artist puts a crease down the hood I don't think that's better.
Yeah Jim,
The crease on the hood was one thing that threw me. Totally not in keeping with the original design concept. I don't care for the monster flares either. I've always been a fan Graham's car, keeping it all under the original body work.
Tim
Tim - I'll be the last one to tell someone not to make changes to their car unless it is a desirable, low number classic that will lose its value. Many of the decisions I made on my car created more work for me because I wanted to retain recognizability to the original. ("Recognizability" will surely be included in the next update to Webster's dictionary). I could have made split bumpers but chose to maintain the look of the early chrome bumpers although I did take some liberty with removing the mounting bolts and with the finish. It would have been much easier to remove them entirely but where's the fun in that.
I feel the same way about stuck on fender flares. It's much harder to include large wheels and tires within the bodywork than to build a patio cover over the top of what sticks out. I think the stepped body line that runs from headlight to taillight is a signature styling cue of the MGB so I worked very hard to maintain it even though the rear fenders are bulged out 1 1/2" beyond stock
Same story with hood bulges or scoops because, to me, it points out that the builder didn't work hard enough to integrate the engine into the vehicle. If a bulge is done for styling reasons and not to cover up some protruding engine part I'm OK with that but that is rarely the reason.
The grille surround is another signature item that could have easily been replaced with a piece of expanded metal. The first attempt duplicated the height of the arc in the top bar of the stock grille surround but it looked out of proportion due to the additional width. I had to remake the top bar with additional height in the arc to match the proportions of the stock grille.
I could have cut off the stock windshield posts and stuck in a piece of Plexiglas but then everyone would look at that and know immediately that the car was cut up. The new windshield has a loose resemblance to a stock one: it is the same height as stock and has a full frame around the glass but it is leaned back 14 degrees from stock - most people don't even notice.
The best comment I got was from a guy who showed a picture of the car to his wife who owns an MGB and told her that he thought the car had been widened. She responded to him " No it hasn't". A lot of people comment that they had one "just like it in college" .Most people at car shows walk right by and don't really notice. Thank goodness for the few that stop to look and just keep noticing the work that has been done.
