General Category => Engine, Transmission, & Rear Axle assy. => Topic started by: waterbucket on June 18, 2016, 04:37:23 AM
Title: Gearbox to bellhousing adaptor thickness
Post by: waterbucket on June 18, 2016, 04:37:23 AM
Can anyone tell me the minimum thickness for an adaptor plate between a T5 gearbox and the aluminium bellhousing. I will use steel for the plate for this, I was thinking 3/8"
Philip
Title: Re: Gearbox to bellhousing adaptor thickness
Post by: BlownMGB-V8 on June 18, 2016, 06:59:49 AM
3/8" is the thinnest I've seen. And about 1/8" at the engine.
Post by: ex-tyke on June 18, 2016, 09:06:13 AM
A couple of things......Make sure that adapter plate thickness chosen doesn't compromise engagement of the pilot bearing/xsmn input shaft....
......and ideally, plate thickness should be  1-1/2 times the bolt diameter (otherwise ideal fastener torque is not obtained)....if 3/8" steel is chosen, I'd use NF fasteners/threads to allow a higher fastener torque than NC fasteners.
