A very good idea for high-powered street cars, as well as race cars.
http://www.mgexperience.net/phorum/read.php?41,945341
Might be OK for the front but I don't know why you'd need it for the rear. On the front it seems it would sort of depend on how far forward your universal was located, might not need it there either. That is, unless you think it might come through the tunnel.
That's exactly what it did to the Alfa driver.
Did the Alfa have a metal tunnel, or was it like the TR's which used paper?
Metal if I remember correctly from photos I've seen of several Alfas in magazines. NHRA has mandated drive shaft safety hoops for decades on most of the higher performance classes. I'd vote for front and rear, although front is probably the most important, especially if you have an open tunnel on the bottom so the shaft doesn't drop and 'pole vault" the car or the spinning shaft rip up the tunnel and driver as the car slows down. A good idea Carl, and definitely one a lot of guys that really push their cars might consider.
I think I'd like one at the rear as well, not too heavy and might save some chassis damage if the U-joint failed.
A hint I learned from a drag racer, when you are installing U-joints that have grease fittings place the fitting so that it is under compression from the engine torque. Doesn't cost anything and just might add that little extra strength to prevent a failure.
