General Category => Steering, Suspension, & Brakes => Topic started by: IaTR6 on August 26, 2015, 02:35:58 PM
Title: steering shaft and support bearings
Post by: IaTR6 on August 26, 2015, 02:35:58 PM
I am building my steering shaft assembly, and am using a double u-joint for the center joint due to the angle. This requires a support bearing on each side, and I selected PTFE lubed bearings with a 3/4" diameter bore. The issue is that the DD shaft will turn within the bearing, and I wonder if I would be wise to use center punch marks on the shaft to create a tight fit that would require the support bearing ball to rotate in the PTFE insert?
Dennis
Title: Re: steering shaft and support bearings
Post by: DiDueColpi on August 26, 2015, 02:59:27 PM
It's not supposed to be a problem but it bothers me as well when that happens.
Rather than modify the shaft I use some scrap nylon (from one of the Lovely Lynne's old cutting boards actually)
Cut a strip and grind it into a half moon shape to use as a wedge into the gap on either side of the shaft.
Once hammered home cut it off flush with the bearing and touch it up with a fine file.
Looks professional and works good.
Live like you mean it.
Post by: IaTR6 on August 27, 2015, 10:45:18 AM
Aha! Great idea Fred, thanks very much. It just so happens that I have some pieces of left-over cutting board. I bought one at a commercial kitchen supply house and cut it into spacers for the body-to-chassis. (one of these days, when I am ready to spend a lot of time at the computer I will start a "how it was done, and you'll see). This is another challenge that debunks the one hour restorations on TV!
Dennis
