General Category => Engine, Transmission, & Rear Axle assy. => Topic started by: Beau Dirt on August 02, 2015, 06:13:34 PM
Title: Olds 215- Do I need a ballast resistor wired in?
Post by: Beau Dirt on August 02, 2015, 06:13:34 PM
Finally getting my 215 powered Model A going. I ave been wiring it. It seems like the coil might be getting hot, but I'm not sure. Maybe it's normal? Just making sure I didn't forget something. right now I just have a wire from the ignition on positive terminal to the positive on the coil. Is ths wrong?
Title: Re: Olds 215- Do I need a ballast resistor wired in?
Post by: 88v8 on August 03, 2015, 04:35:42 AM
Remove the coil connections, put a meter across the +/- terminals and check the resistance.
If it's a standard 12V coil you'll see around 3 ohm, and that doesn't need a ballast.
But if you see 1 - 1.2 ohm then it requires a ballast. In that case you should also make a direct 12V connection to the coil for starting - take a feed off the starter terminal.
Post by: Beau Dirt on August 06, 2015, 09:21:14 PM
OK. I understand the need for a wire from the starter to the coil. The stock Olds 215 wire diagram shows a resistor wire, so I know I need one. My question is what size? How are the rest of you doing this? Are you running coils with a built in resistor?
Post by: 88v8 on August 07, 2015, 09:44:45 AM
This is a ballast.
http://www.flyingspares.com/shop/rolls-royce-bentley-shadow-t1-t2-corniche-mpw/ignition/shadow-t-1-twin-point-distributor-cap-leads/main-components/twin-single-point-distributor-ue34105.html
Probably the most expensive you could find.
Here's another.
http://www.ebay.co.uk/itm/like/171518781908?hlpht=true&hlpv=2&rlsatarget=&adtype=pla&ff3=1&lpid=122&poi=&ul_noapp=true&limghlpsr=true&device=c&chn=ps&crdt=0&ff12=67&ff11=ICEP3.0.0-L&ff14=122&viphx=1&ops=true&ff13=80
I bet they're pretty much the same.
What resistance did you see across your coil?
Ivor.
Post by: Beau Dirt on August 07, 2015, 04:56:40 PM
I ended up getting one at O'Reilly Auto. Part number RU6. The price was $6. Maybe this will help other in the future.
