TR8 3.08 rear diff drum to drum - $300
TR8 instrument cluster (needs clear face cover) - $200
TR8/SD1 Federal Fuel Injection system with harness(NO computer) $250
TR8 drive shaft $100
Leyland P76 4-speed bellhousing - $225 (fabricated adapter plate required to work with Ford Mustang V6 T5 with long input shaft)
Leyland P76 bare block - $200
Leyland P76 3.5" stroke crankshaft and flywheel (crank cut 10/10) $400
SD1 exhaust manifolds - $100
SD1 alternator bracket - $75
1964 Buick 300 aluminum intake 4 bbl - $200
1962 Buick 215 4 bbl intake - $100
D&D Vega 215 notched oil pan - $150
D&D Vega 215 crossmember mount brackets $150
Advance Adapters bellhousing to mate Toyota R154\\jeep AX15 to Small block Chevy\\BOP - $250
Advance Adapters plate to mate Toyota R154\\jeep AX15 to Small block Ford bellhousing - $225
Novak Adapters plate to mate Toyota R154\\jeep AX15 to Small block Chevy\\BOP bellhousing - $225
Greg
greg55_99@yahoo.com
Sturbridge, MA
